Author Topic: Ed30/R32 Inner Lights  (Read 1569 times)
Offline Lyons
  • -Given: 22
  • -Receive: 31
« on: October 03, 2015, 08:26:26 AM »
I'm looking for a set of inner rear lights as my DIY attempt has failed.
Anyone have any?
Offline Rossimac
  • -Given: 90
  • -Receive: 36
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=265e4lbvb77frndq57ahonqgp2&/topic,90767.0.html
Re: Ed30/R32 Inner Lights
« Reply #1 on: October 03, 2015, 01:48:56 PM »
What went wrong with the DIY ones Lyons?
Offline SI-R32
  • -Receive: 124
« Reply #2 on: October 03, 2015, 03:39:59 PM »
I've just bought this and its other half, i know there for Europe and not uk but hoping to swap lenses, if not i'm 70 quid down :(
http://www.ebay.co.uk/itm/VW-Golf-Mk5-R32-Hatchback-2005-2008-Inner-Tail-Light-Rear-Lamp-RIGHT-RH-/151401448684?hash=item23403ac4ec
i'll let you know how i get on if you wanna order a set
Offline Lyons
  • -Given: 22
  • -Receive: 31
« Reply #3 on: October 03, 2015, 05:51:20 PM »
I noticed part of the edge has split, maybe just not enough bond. Couldn't be bothered doing s half assed job again!
Si, when are they due? I'd be keen to hear the outcome.
Offline SI-R32
  • -Receive: 124
« Reply #4 on: October 03, 2015, 06:01:48 PM »
Sadly not till around 16th,  I'll keep you posted anyway
Offline v4rley
  • -Given: 31
  • -Receive: 112
« Reply #5 on: October 03, 2015, 06:44:39 PM »
Swap should be achievable and fairly straight forward. Several people on here (inc me) have swapped our inner rear fog red lens for a clear to match the reverse for a bit of symmetry.
Offline SI-R32
  • -Receive: 124
« Reply #6 on: October 03, 2015, 06:52:12 PM »
Cool,  I've done it 3 times with the valeos,  but fed up of led clusters burning out,  but didn't know if you could do with standard R32 lights
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #7 on: October 04, 2015, 10:15:21 AM »
I just bought 2 new inners from VW...... Gulp! Also had the wrong part numbers so had to swap lenses as they were LHD. Easy to swap with needle nose plyers though
Offline Lyons
  • -Given: 22
  • -Receive: 31
« Reply #8 on: October 04, 2015, 04:29:55 PM »
Hoe much did they sting you?
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #9 on: October 04, 2015, 07:47:13 PM »
£145 for the 2. Nearly fell over but cant find them cheap anywhere apart from the above. I remember when a new full set was only £180 off ebay.
Offline SI-R32
  • -Receive: 124
« Reply #10 on: October 13, 2015, 09:57:03 AM »
Just received the fog yesterday hopefully reverse today, made by Magneti Marelli as were the 2 outer units i bought from a UK supplier, all made in Poland as are the Valeo and Hella units so i would imagine they would all be made by same people.
Nothing wrong with light at all, cheery red all ok, as others have said easy to change the red and white lenses over to make it right for the UK so in all got a whole brand new set of cheery reds (wish i hadn't had sold my OEM's) for approx £180 well worth the scour on ebay
Offline Lyons
  • -Given: 22
  • -Receive: 31
« Reply #11 on: October 13, 2015, 12:55:30 PM »
Excellent news, thanks Si.
My outer units are also Magnetti Marelli (bought from ECP), so these sound like they are part of the same range. Not sure why ECP don’t do the inners.
I paid £45 each for my outers, so effectively that’s a brand new genuine set for circa £160!
Let me know when you get the rears swapped.
