Author Topic: Brake Bleeding Procedure  (Read 621 times)
Offline monk180
« on: January 11, 2017, 07:27:52 PM »
Hi Folks,
After having the sensor in the pedal for the ESP fixed, the brake pedal is spongy, and if you press on it firmly for a period of time goes to the floor. Not a good thing if you are braking slowly from high speeds.
I hear that you have to use software to bleed the system by running the ABS pump.
What is this software, and the procedure?
Offline TAPPY
  • -Given: 19
  • -Receive: 58
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=impa1r24lj3lp09pa1k9l11rr0&/topic,103290.0.html
Re: Brake Bleeding Procedure
« Reply #1 on: January 11, 2017, 08:16:11 PM »
Offline monk180
« Reply #2 on: January 11, 2017, 10:14:31 PM »
Thanks - yes the brakes to feel better after some ABS / ESP action.
Offline skard
  • -Receive: 245
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=impa1r24lj3lp09pa1k9l11rr0&/topic,62636
« Reply #3 on: January 11, 2017, 10:56:30 PM »
See http://www.micksgarage.com/blog/project-gti-how-to-bleed-your-brakes/
Coincidentally, I totally flushed my Touran brake fluid today.
As usual, after running the ABS pump the colour was manky. When I bled the clutch it looked like old engine oil coming out.
