Author Topic: Stasis Brake kit  (Read 1167 times)
Offline tommygti
  • -Given: 22
Stasis Brake kit
« on: January 11, 2018, 10:03:36 PM »
Stasis big brake kit
£575.00
Postage: £12.00
Delivery or Collection
For sale is my used Stasis 4 pot brake kit. Come with Alcon 4 pot calipers which are probably up there with the best make you can get. I never got round to fitting these but you will most likely need 19" wheels due to the size of the discs or at least 18"s with good clearance.
The kit can be found here: http://www.stasisengineering.com/…/brakes-370-mm-mono4-tta3…
The kit comprises of:
- 4 pot Alcon Calipers
- used 370mm x 32mm 2 piece floating discs with bells
- used pads
- Caliper carriers/adapters
- braided hoses
The calipers are in ok condition. Had a few scraps as you can see from the pics so could do with a refurb. The pistons and seals are fine. The pads have roughly 3/4mm left on them. No cracks in the bells or discs. 26.6mm left in the discs. Sold seen.
Genuine replacement discs can be bought here: https://alconkits.com/stasis-parts or can be sourced from places such as Reyland Motorsport
Will fit golf mk5/mk6, S3, A3, A4, Leon, etc.... most VAG cars with 5x112 hubs.
Postage or collection available
£575
Sold
Audi S3 Alloy wishbones + Superpro ALK,
£275.00
Postage: £10.00
undefined
Audi S3 Alloy wishbones with upgraded Superpro front bushes and Superpro Anti Lift
Fitted for roughly 8000 miles. Great condition. A few minor scuffs to the consoles as standard.
Sold
Upgraded Alloy Radiator
£85.00
Postage: £10.00
Upgraded Alloy rad to fit golf mk5 gti. I think the make is Direnza. Never fitted so in near new condition. A few of the fins are slightly bent as you can see in the pics but this does not affect performance.
Basic spec:
- Engineering; Radiator is Made of High Quality T-6061 Full Aluminum for Maximum Cooling Efficiency
- Improve 35-45% Cooling Temperature
- Specially Welded 2 Row Design to Maximize Cooling
- Overall size: 30.25" (L) x 16.25" (H) x 2" (W)
- Core size: 25.5" (L) x 15.75" (H) x 1.75" (W)
- Inlet/Outlet: 1.25" / 1.25"
Will fit golf mk5/mk6 gti, edition 30, S3, A3, Leon, Octavia, and other 2.0 tfsi engines
Collection or courier available.
« Last Edit: February 12, 2018, 04:52:35 PM by tommygti »
Offline tommygti
  • -Given: 22
Re: Stasis 2 piece discs + S3 alloy wishbones and Superpro ALK
« Reply #1 on: January 13, 2018, 06:33:11 PM »
UPDATED
Offline tommygti
  • -Given: 22
Re: Stasis Brake kit + upgraded alloy radiator
« Reply #2 on: January 17, 2018, 10:40:47 PM »
Upgrade bump
Offline tommygti
  • -Given: 22
« Reply #3 on: February 05, 2018, 08:59:09 PM »
reduced bump
Offline tommygti
  • -Given: 22
« Reply #4 on: February 12, 2018, 04:53:16 PM »
Need these gone. Stupidly low price considering each caliper costs over £1K new.
Offline Pudding
  • -Receive: 313
« Reply #5 on: February 16, 2018, 10:18:37 AM »
That is a good price and Alcon are superb brakes, however I think you know people are being put off by the caliper appearance and the cost of replacing the pads and rotors.    These brakes have led a very hard life and waaaaaaaay past the rotor wear limit.  26mm!!!   Should be replaced at 30mm.
Black Edition 30 with manually selected cogs, a beefier clutch, some extra boost and them Whiteline thingies, otherwise standard.
