Author Topic: Passat alloy wishbones to mk5 hubs  (Read 2758 times)
Offline JamesED30
Re: Passat alloy wishbones to mk5 hubs
« Reply #60 on: July 13, 2018, 07:37:37 PM »
Looks like I’ll be selling my alloy hubs then.
What weight saving is there solely in the wishbones?
Offline Christiank
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=61uqrgkkuallmv3vl71v8dcbt7&/topic,110924.0.html
« Reply #61 on: July 13, 2018, 07:50:54 PM »
Well the major weight saving in this setup is from caliper and discs.
I think alloy vs steel hubs as 1.8kg pr side or something like that. Total weight saving using wishbones, hubs and the 986 setup is over 18kg pr side.
MK5 TDI 2.0 MY2005 - FULL OF RETROFITS:
MK6 dashboard - MK6 R MFSW - Cruise Control - Discover Media 2 - 2016 Passat Climatronic panel - 8 Sensor parking kit - Interior door handle illumination - Door entry lights - TMPS - Custom made 3D cluster - Side Assist - TMPS Highline - Veyron modded LED taillights - NQSBBK front and rear upgrade... And a whole bunch of other stuff!
Offline JamesED30
« Reply #62 on: July 13, 2018, 09:52:52 PM »
Compared to which setup buddy?
Offline colesey
« Reply #63 on: July 14, 2018, 05:24:19 AM »
Think there must be some mistake over the 18kg per side claim as Boxster calipers will save @3kg over the stock GTi ones.
Offline JamesED30
« Reply #64 on: July 14, 2018, 08:09:05 AM »
Yeah that’s what I thought. Maybe 8kg if it had been possible. Or 18kg total.
Offline colesey
« Reply #65 on: July 14, 2018, 08:59:10 AM »
IIRC stock 312mm brakes are @15kg per side split roughly 50/50 between disc and caliper. NQSBBK will save @3.5kg per side and the alloy control arms @1.5kg, so @10kg total saving is available. That said, the guy with the stock brakes can also fit alloy hubs as well as the control arms, saving @7kg himself.
Offline JamesED30
« Reply #66 on: July 14, 2018, 09:38:24 AM »
So the ali hubs are only 2kg lighter than the steels!?
I thought it was more. 😂
The complete assembly’s are pretty light. I’m just having mine blasted. But will be up for sale when I get them back.
