Forum News
Forum Donations 2024
on February 25, 2024, 11:16:50 am
HI Guys
Its been over a year since our last request for donations. The forum kitty is empty again  :scared:
I have setup another donation page. The donate banner should also take you to the donation page.
Thanks again for your support  :congrats: :congrats: :congrats: :congrats:
https://www.paypal.com/pools/c/122584255034758241
Re: Upgrade injectors for k04 turbo (fsi engine)
Last Poster: Doomhand in Mk5 General Area on Today at 06:27:54 am
Take a look at german ebay (eBay Kleinanzeigen). I've seen them selling packs of 4 S3 cleaned injectors for 400 euros
Thanks a lot! I will look into those.
Re: Mk5 Headliner Replacement - Suggestions
Last Poster: ZoliWorks in Mk5 General Area on Today at 06:25:41 am
This is where I'#039m getting mine from when I'#039m redoing my interior. They also have alcantara with 2 sided tape already applied to it which is much easier but I'#039m going for that OEM look. Don'#039t go full black, go anthracite, it doesn'#039t look good.
https://sekerciotokumas.com/en/product/lakost
Re: K04 Conversion - Do you ever regret it? How is it for daily driving?
Last Poster: ZoliWorks in Mk5 General Area on Yesterday at 08:04:43 pm
Aight, went with the second option. Got a $420 used K04 off of a 2.0 TFSI BWJ that the owner upgraded to a GT35xx, built the engine and is now pushing well over 600hp according to his dyno logs. Turbocharge is by no means new but for a 225k km charger is in a pretty good shape with close to no play in the compressor wheel. In case it does break later on, it'#039s a $300-$400 repair wh
Re: VW Golf MK5 2006
Last Poster: Octoparrot in Mk5 General Area on April 17, 2024, 01:20:38 pm
First thing I'd be looking at is the accessory drive belt, pulleys, alternator etc.
Re: running rich and lpfp low pressure at high rpm
Last Poster: jolozj in How to Guides / Troubleshooting on April 17, 2024, 06:55:10 am
anyone?
Re: Buying this mk5 off Facebook marketplace.. is it a good deal?
Last Poster: OllieVRS in Mk5 General Area on April 17, 2024, 01:14:33 am
1. Check the service history. The car should have been serviced every 10k miles, ideally less. Lack of oil changes can lead to oil system related failures, so the money you save initially ends up costing the same or more down the line.
2. Ideally you'#039d have someone with VCDS (Ross-Tec) check the car for fault codes, as this can quickly reveal any problems the car has, even pr
Re: GTI grill badge
Last Poster: ZoliWorks in Mk5 General Area on April 16, 2024, 05:12:59 pm
In all fairness, Aliexpress. I've got my R2.0 badges, GTI badges, wheel emblem caps and some 2.0t and gti stick-on badges. They are quite good tbh.
Re: HOW TO: Replace Faulty Door Lock Module
Last Poster: Wilywalt in How to Guides / Troubleshooting on April 14, 2024, 12:41:26 pm
Just want to say a big thank you for the guide, helped immensely with changing the lock on a VWGolf Plus 2006, though a little longer as I had to use an angle grinder on the lock bolts having sucked in a large breath! Lost the small rubber that held the handle chassis but easily replaced.
Note that the issue was the "quotred"quot lever was not fully engaging when using the re
Re: Good respray Tornado Red for door and bonnet.
Last Poster: madnemo in Mk5 General Area on April 14, 2024, 12:04:42 pm
There's a very good bodyshop in north london/Hertfordshire. Heart and soul paintwork. Mainly do alot of vw resto/show cars etc
https://www.instagram.com/Heart_and_sol_paintworks/
Re: Alex's Shadow Blue GTI
Last Poster: madnemo in Members Rides on April 14, 2024, 10:20:54 am
Your shadow blue gti is immaculate 💙🔥. Just read all 5pages and its an inspiration too get my shadow blue to your standard 🙂
Re: Question for those that have had their sills replaced
Last Poster: Marticus in Mk5 General Area on April 13, 2024, 12:28:52 pm
Fitting part 9 would have to be perfect or the skirts wouldnt sit correcty. OCD would kick in nbsp :scared: :scared:
Yeah exactly, that'#039s why I was hoping there is a version of the sills pre drilled or at least marked for the screws, it would be near impossible to get it righ
Re: Metallic sound from engine, possible timing stretch?
Last Poster: hcmzah in Mk5 General Area on April 12, 2024, 04:53:38 pm
Thanks for the response, I did end up doing the chain and tensioner along with the adjuster and it'#039s now a lot quieter and the sound has gone.
However, I did hear a lot of ticking from the purge valve, so I put back my old one and that'#039s also a lot quieter
Reason I changed the purge valve initially was because of the P0441 code but that was due to needing a new ch
Re: GTI grill replacement
Last Poster: Lewo in Mk5 General Area on April 12, 2024, 10:55:19 am
Forgot to say I put some c4 on the unpainted bits which has lasted well.
Re: What hose is underneath the vacuum pump?
Last Poster: terrier in Mk5 General Area on April 11, 2024, 05:29:56 pm
Good excuse to replace the coolant and temp sensor :happy2:
 M e giving advice when ive had this and a duel pump sitting in the shed for 4 months :grin: :grin:
Re: New member
Last Poster: Clarky in Members Rides on April 11, 2024, 10:56:35 am
Welcome to the forum!
Re: Adolf the Golf
Last Poster: Clarky in Members Rides on April 11, 2024, 10:54:13 am
@Octoparrot I couldn'#039t agree more, for the money and the overtaking shove it was worth it. True enough i don'#039t have the sticker on the window of some insta-famous tuner but they have been around enough years and must have done thousands of maps over different platforms to know roughly what they are up
K03 turbo outlet diameter
Last Poster: ajmludders in Mk5 General Area on April 10, 2024, 10:43:15 am
I am thinking of upgrading the full exhaust system from the OEM stock but wondering if a 3-inch system will fit onto the stock k03 turbo mounting?
So for example would a Miltek 3-inch downpipe fit onto the K03 turbo mounting?
Thanks in advance!
Re: Newbie
Last Poster: mjmallia in New Member Intro's on April 08, 2024, 09:13:49 am
Re: Newbie
Last Poster: mjmallia in New Member Intro's on April 08, 2024, 09:13:27 am
Re: Forum Donations 2024
Last Poster: mjmallia in Announcements on April 08, 2024, 08:33:05 am
Done
Shoutbox
Sold
2008 Volkswagen Golf GTi Edition 30 - Steel Grey - 5 Door - Stage 2+ (DSG)
£10995.00
Collection Only
Hi all,
For sale is my 2008 Volkswagen Golf GTi Edition 30 (DSG). I am the 2nd owner from new and have owned the car since November 2021. The car was near enough stock when I purchased it and I have upgraded it in my ownership.
- 5 door.
- DSG.
- Steel Grey.
- 76,000 miles (will rise as still in use).
- FSH - last serviced December 2023.
- MOT - Expires 7th March 2025.
- Xenons.
- Heated seats.
- Highline MFD.
- Arm rest.
- MFSW.
- RNS510.
- Folding mirrors (heated).
- Rear parking sensors.
In my ownership I have had the following maintenence completed:
- Serviced 3 times (2 full services, one oil and filter change).
- Cambelt and waterpump.
- Thermostat replaced.
- DSG service.
- Genuine cam chain and tensioner.
- Genuine cam follower changed at every service.
- Genuine oil pick up pipe.
- Rocker cover gasket.
- Genuine PCV.
- Genuine Diverter valve.
- Subframe spacer kit.
- Brake vacuum gasket.
- Varta E44 heavy duty battery.
- New rear wiper switch.
- New folding mirror switch.
Upgrades/modifications are as follows:
- Brodit angled mount.
- Suede retrimmed headliner.
- Wheel finesse steering wheel wrap.
- Ram air oversized induction kit.
- Turbo back exhaust comprising of an MPD developments downpipe with sports cat and a Miltek cat back.
- VIS Stage 3 HPFP internals.
- Genuine R8 coilpacks.
- MK7 Golf Gti performance front calipers, discs and pads.
- Tuning technics Stage 2+ lite remap (approximately 355-360bhp).
- Tuning Technics DSG remap.
- H&R front and rear anti roll bars - fitted December 2023.
- Whole car has had Powerflex bushes installed in December 2023.
- Super pro anti lift kit - fitted December 2023.
- AP coilovers (top mounts replaced all around at the same time), fitted December 2023.
- All rear control arms replaced (December 2023).
- Geo By Luke fast road alignment (December 2023).
- Michelin Pilot Sport 4 tyres all around.
I've just spent circa £2.5k on the suspension components refresh.
I have spared no expense on ensuring the car is mechanically sound.
Being honest, the car could do with the wheels being refurbished. There is general wear and tear on the car which is expected for the age, the car is approaching 16 years old. There are some minor dents and scratches. The front end does have some stone chips. The inner sills have some slight blistering to the paint. The MFSW buttons work intermittently but I have bought the new control module but haven't had this fitted yet. The cruise control is also intermittent and I have purchased a new stalk, but haven't fitted this yet. Parts will be included in the sale, or if I have time, I will get them installed before sale.. Front and rear dash cams & pioneer double din are not included in the sale.
If you are looking for a well sorted car which mechanically has been looked after well, this is a good car to purchase.
I am in no rush to sell, only considering selling to upgrading. No part exchanges please.
The pictures are prior to the installation of the coilovers, I will upload new pictures once I have detailed the car.
I'm looking for £11,495.00, I paid just under this when I bought the car stock.
Please let me know if you have any queries.
Kind regards,
Sharif
2 x Mk5 Gtis being broken, West Midlands
£0.00
Postage: £0.00
Delivery or Collection
I have, in annoying and frustrating circumstances, ended up with 2 Black Gtis that are both dead on my drive, both for engine reasons, so I couldnt even get away with making a good one out of the two, and have had to replace them both with an R32!
I will start pulling them apart and will list stuff separately as I have the chance, however, due to lots of stuff that is going on at the minute, that may take me ages, so I thought a general post about both being broken may be helpful for anyone who is after specific bits etc.
One is an 05 5 door, block and head are totally scrap.  Was in daily use until a couple of months back when the engine lunched itself.  Pretty much all standard.  Of note off the top of my head has:
- Heated Leathers in decent condition
- Standard Grey Leather Gti Steering wheel
- 17" Monzas with decent Tyres
-  Midline Clocks
- Generally things are pretty tidy, so anyone who needs standard bits like engine cover, trim, light covers etc etc etc, they might be of use to you.
One is an 06 3 door, with a few more tasty bits and pieces on, but that has been sat for longer.  Again, engine itself is lunched.  Again, from the top of my head there is:
- Heated Cloth interior in not bad condition
- Black MFSW
- Cat Back Stainless, although the cat itself was getting borderline on MOT passes, so maybe just the backbox of use
- 18" Monzas
- Neuspeed Intake
- Twintercooler Setup
- Reversing sensor setup rear bumper etc
- Highline clocks
There will be other decent bits on both - As I say, I am working a bit off memory at the minute.
I just need the cars gone, so once I get started, really I just need it all out the way, so not especially bothered about getting top dollar for bits, I just need the space back, but know that the bits on them both are too good to let go for scrap.
I am based just outside Walsall in the West Midlands, but work in Cardiff, so go there most weeks, and am happy to take stuff there (or meet people in between).
Shout if any questions, and as I actually get stuff off I will get pictures up, but if people want me to get pictures of anything specific, let me know and I can do.  I am actually listing this right now when I am away from home with work for a few days, as thats the only way I actually get time to, but feel free to send me questions etc and Ill answer best I can, then send pics when I get back.
I dont love posting car bits out - There is too much room for stuff to get damaged, go missing etc  - I would much rather collections, or meet you somewhere etc in an ideal world, but it can possibly be arranged on some stuff.
Dan
Superpro Aluminium Wishbone Kit and H&R Front ARB 28mm *PRICE REDUCED £350.00*
£350.00
Collection Only
I'm selling a brand new boxed set of SuperPro Aluminium Front Wishbone set £495.00 and H&R front ARB 28mm (33258-2) £225.00, bought item's to fit on my Ed30 but I have since sold the ed30 so  these are now surplus to requirements.
Cash on collection, will listen to sensible offers.
Sorry no PayPal and will not split as need both items gone together please...
Thanks for looking!
Complete set of MK5 GTi rear lamps
£25.00
Collection Only
A complete genuine set of rear lamps in excellent condition for golf MK5.
There are for GTi model.
Calico Coated Rod Bearing Set for VW (IE rods)
£80.00
Single Image
    Postage: £0.00
    Brand new Calico Coated Rod Bearing Set for VW/Audi 4CYL With IE Rods
    IMPORTANT: Factory rods do not accept tang bearings and are not compatible, these are for use when installing with IE Rods only
    I have IE Forged rods also for sale; PM if interested in both and we could work a deal.
    Doing local pickups preferably but can post as well.
    Located in Miami, Florida
    More info on bearings:
    https://performancebyie.com/products/calico-rod-bearings-vw-audi-4-cylinder
    • users Users: 4
    • guests Guests: 447
