All Things Mk5 => Mk5 General Area => Topic started by: Dij303 on April 16, 2018, 06:45:20 AM
Title: Oil consumption
Post by: Dij303 on April 16, 2018, 06:45:20 AM
My last question on here was regarding oil consumption in my Mk5 GTI. Last time I filled up with oil I reset the trip and have done about 600 miles. The oil level is now nearly at the min line so due a top up. Is 600 miles about average or does this seem unusual? Currently using 5w 30 by the way.
Title: Re: Oil consumption
Post by: Dawsy on April 16, 2018, 07:20:48 AM
I believe VW have stated that upto 1 litre every 1k miles is acceptable in their book.... I have a stage 1 remap and am currently using 5w40. I have only owned the car 5 weeks but have probably done around 700 miles in that time. The oil level hasn't moved. As I understand it 5w40 is best suited to any modified or high mileage vehicle so may be worth giving 5w40 a go?
Regards
Martyn
Post by: Dan_FR on April 16, 2018, 07:45:37 AM
Yours is high but not unheard of. Do yourself a favour and service it using a good quality 5W40 oil
Post by: Dij303 on April 17, 2018, 07:18:37 AM
Regards
Martyn
Many thanks for your response Martyn. The only modification on mine is the exhaust so doubt that would have any impact on oil use? It has just over 100k on the clock so relatively high. I’ll give 5w40 a go and see if it makes any difference.
Post by: Dij303 on April 17, 2018, 07:20:07 AM
Cheers Dan.
Do you think a complete oil / filter change is a good idea or just top it up with 5w40?
Post by: Dale on April 17, 2018, 09:01:15 AM
Do a complete oil and filter change as there's no point just topping it up with 5w40 as you'll be mixing it.
Post by: Dan_FR on April 17, 2018, 11:32:41 AM
As above, full change is best. No need to go out and do this immediately if you're not due a change, but its definitely worth swapping to a 5W40 at your next service.
Post by: Dij303 on April 17, 2018, 12:25:28 PM
Sound. Thanks for your help
Post by: Dij303 on April 17, 2018, 12:26:06 PM
Makes sense. Cheers
Post by: Pudding on April 17, 2018, 04:32:05 PM
Try Mobil 1 FS X1 5W50.  5w40 won’t do much to an engine that’s burning a litre per 1000km.
Post by: Panthera on July 01, 2018, 12:27:36 PM
Mine seems to be using a little more oil in this recent heatwave we are currently having. I am using Castrol Edge 5w40.  My GTi is stock with 103k on the clock.
Half tempted to try 10w60 stuff that my VAG specialist recommends.
Post by: thenorthster on July 01, 2018, 06:58:22 PM
Perhaps I'm one of the lucky ones, then - my levels don't seem to have budged over a year when going from 100k to 107k miles
Post by: Dan_FR on July 02, 2018, 07:17:09 AM
I'd check your fuel pump isn't leaking fuel and diluting the oil :signLOL:
Post by: ROH ECHT on July 02, 2018, 06:51:14 PM
Is there an Oil Analysis Lab there? Their result would tell you if there are signs of excessive fuel in the oil.
I would bore-scope the intake valves for carbon buildup. This points to a few possibilities though. Leaking valve stem seals and guides is one. Cracked or "no longer sealed" EVAP and PCV channels inside the valve cover is two. Turbo bearing/seal is a third possibility. Just up to you how or even if you want to sort it all. VW doesn't consider oil loss worthy of warranty replacement until it consumes 1qt/600 miles here...likely 1L/1000Km there. So you are at a level of high loss. Choose; if keeping the car and going to invest in it...start somewhere and begin eliminating the possibilities. Otherwise; sell it and move on because it isn't going to get any better without some first-aid. A full 100% synthetic oil will buy you more time...not any Oil that states 'Full Synthetic" because they only need be greater than 50% syn to be allowed to state that...but use oils that are actually 100% synthetic like LiquiMoly 5w40.
