All Things Mk5 => How to Guides / Troubleshooting => Topic started by: shoaybmakda on September 20, 2017, 10:55:08 pm
hi
just recently bought a mk6 airbag to go with my wheel but not sure where the pins go on the airbag to connect it up.
anyone have any pics or guides on how to connect the loom to the airbag?
thanks
anyone?
its the only pic i have, hope it helps
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi812.photobucket.com%2Falbums%2Fzz45%2FSI-R32%2Fsteering%2520wheel%25201%2F20151212_174501_zps91jspevx.jpg&hash=fdaaf6b8ebc8fbfbe92447ff7cecf4bc8da04b2b) (http://s812.photobucket.com/user/SI-R32/media/steering%20wheel%201/20151212_174501_zps91jspevx.jpg.html)
@SI-R32 (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=1757) thanks for that I can just about make it out which helps
Can any of the pins go onto where the hooks are? I’m just worried about blowing they airbag once the battery goes on!
When I did mine I put the pins anywhere on the hooks and it's been fine ever since so I'm guessing so !
Sent from my SM-G930F using Tapatalk
@Kai96 (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=16484) just don’t want the airbag blowing in my face when I reconnect the battery! Lol
Shouldn't do I remember just plugging mine into any didn't even think about them having a specific placement . Let us know how you get on
@Kai96 (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=16484) fitted it today - looks and feels much better!
No blown airbag thankfully!
Cruise control not working however - not getting picked up reckon might be a dodgy stalk. Horn out of action too..
When I first fitted mine it was the same the horn wasn't working but once somebody coded it all it started working again, and I've read somewhere if you switch to the mK6 steering wheel you might have to change the cruise stalk depending on which one you have at the moment
Didn’t know I had to recode the horn - I’ll have a look
Yeah I fitted a rev G stalk but it’s come from China so I think might be a dodgy one.
Getting this error on VCDS
http://wiki.ross-tech.com/wiki/index.php/00895
Guessing you're using the ch module?
Are you coding up the wheel with 5-8 lin 2 as this is mk6 NOT 1-4 lin 1.3?
Cruise is coded number 3 in its correct position, not 1 or 0?
@SI-R32 (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=1757) yep it’s a CH Module.
I think I might have coded it wrong now you mention it..I don’t think I put any numbers between 5-8 I’ll have a check tomorrow to see what I’ve done.
Mines a DSG with cruise installed via blinker stalk so I think I need to have my coding set to 0001834 as per what’s shown in the bubble in this link
http://www.mk5golfgti.co.uk/forum/index.php/topic,111328.15.html
Had a look and it did have an 8 in there for multi function with Tiptronic and push to talk installed.
Put the code in and now I get the following which suggests to me the stalk may be buggered:
http://wiki.ross-tech.com/wiki/index.php/16952/P0568/001384
got the cruise working!
just the horn to sort out but that might be due to where the pins are placed on the airbag?
