General => Product Reviews => Topic started by: john_o on February 12, 2009, 01:19:21 pm
Why
The diverter valve is prone to failure on both
std GTI (K03 dv cited nr turbo)
and
Edition 30 / Pirelli (K04 dv relocated to front of engine) models *
Often this can go undetected.
Having an accurate working vacuum/boost gauge allows you to continuously monitor your engine.
* - VW have now produced a new verson of the DV with a completely new design to hopefully eliminate failure
Check out this thread http://www.golfmkv.com/forums/showthread.php?t=75232 on golfmkv.com
Its not a given that the reciting away from the turbo improved things! (but it cant have hurt)
My main focus was on the quality of the gauge as a priority which is why I chose DEFI.
Sourcing
1. OSIR RHD opod mono gauge pod
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fhomepage.mac.com%2Frisowu%2FOSIR%2Fimages%2FO-Pod_mono01s.jpg&hash=643b293d69593f587f744332a78c5874fd8c1e32)
>> OPOD link << (http://homepage.mac.com/risowu/OSIR/O-PODMONO.htm)
Vented single gauge pod for all MKV Golf and Jetta*
Angled towards your sight
No cut no special skill needed
Simply plug & play
Fit 60mm & 52mm gauge (52mm step down ring included)
*Demonstrated with Defi BF TURBO gauge (gauge not included)
Available in LHD and RHD
2. DEFI Blue Racer 52 mm Boost Gauge
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fwww.defi-shop.com%2Fproduct%2Frg%2Fimages%2Fdf06501.jpg&hash=faf9157f603250eb05158bec8185d92cfbb213eb)
>> DEFI link << (http://www.defi-shop.com/product/rg/rg_top.html)
display in -30inHg to +30PSI (you can get -100kPa to +200kPa i.e. bar)
3. Forge Motorsport Boost gauge Fitting Kit
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fwww.forgemotorsport.co.uk%2Fimages%2Fproducts%2FFMBGFK.jpg&hash=6c6eae9c5fbc5e02dd5137c6294544bdd45b707b)
>> Forge link << (http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=260303&product=FMBGFK)
note this is for the 2.0TFSI , theres another kit for the newer TSI cars
1+2 are from the TT shop , 3 from forge direct.
theTTshop = superb , no hassle , ordered and (as expected) it arrives sometime later.
>> TT shop link << (http://www.thettshop.com/)
forge direct = ordered online and arrived in 1 day.
Number 3 is useful as it is very neat and provides 3 feeds as required , all tubing etc is supplied.
Its not cheap but in my opinion worth getting.
If you have the Forge dump valve, then you dont need this kit as it already has a boost takeoff point
that the OE part doesnt have.
Cost
£40 for the OPOD mono
£140 for the DEFI 52mm gauge
£40 for the forge fitting kit
£? probably not that cheap if you get a garage to fit one
Fitting
I chose to fit this myself, as it was a good opportunity to get the engine cover off for the first time.
[if you have the OE diverter valve]
1a. Fit the forge fitting kit. I only needed 1 takeoff so the rest were filled with the supplied screws
(NB: removable loctite applied)
Plumb the pipe you have from forge fitting kit takeoff to boost sensor from defi kit.
[if you have the forge replacement diverter valve]
1b. Plumb the pipe you have from diverter valve nipple to boost sensor from defi kit.
(I put the sensor hanging from the screw holding the air intake on)
Ensure they are zip tied as they are under boost!
2. Now feed the cable that connects boost sensor to gauge from inside engine bay into cabin through grommet down near battery
You do it this way as the connector at gauge end is much smaller than sensor end.
Be careful you dont break/yank out the connector wires!
3. Feed wires from grommet through dash into vent by any means possible
(Hint : I used wire coathanger + taped wire to that to feed wires throgh various bits)
4. Fit gauge electrical connections
Take panel off right hand side (bit hidden by door being closed) of dash.
Voila the fuse box
One of the top connections should be free but still powered with ign on (use multimeter)
I chose to connect all live,switched live and ilum wires together then use a spare fuse to hold the wire into the connection.
The only other wire left is ground (strip wire back and undo a bolt , wrap it round + tighten)
5. Attach adapter ring to gauge (its a specific way round)
fit gauge to pod
attach 2 connectors (1 for sensor , 1 for power) to gauge
6. stand back + admire.
Check for boost leaks, go on the forums and work out the expected boost levels for your car.
I configured mine to run on switched 12V feed only
I configured mine to run in permanent 'night illumination mode' as my preference.
I removed outer plastic needle position indicator to leave polished edge , looks better imho
All power taken from free position in fusebox behind RHD panel in door shut.
If you wish to use the dimming function with your lights,
there will be an additional step to wire the dimming cable into the roller dimmer switch.
[as noted I preferred NOT to do this, both because it was too light non dimmed AND I didnt want to cut OE wires]
So a few pics
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fwww.johnoldfield.dsl.pipex.com%2Fimages%2Fweblog%2Fboost_guage_arrives.jpg&hash=3841ff74fba2bc06729067c64a70217699a1607f)
1st pic is the stuff that came , note the OSIR 52mm adaptor on the gauge,wiring harness,boost sensor etc
2nd pic is gauge without the plastic bit on the outside , which I like better than 4th pic
3rd pic is gauge without the plastic bit on the outside
4th pic is gauge in the pod supplied by DEFI which is actually very discreet
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fwww.johnoldfield.dsl.pipex.com%2Fimages%2Fweblog%2Fdefi_small.jpg&hash=06a1344be0047ff61b1b72fd557ba6ffc8b7d240)
Actual dash shots for day and night
(may 2009 : added pic of the 'easy' wiring lol)
Note : earth is black wire attached to screw
all other three (switched live/permanent live and illumination) are together into 1 switched live free point.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fwww.johnoldfield.dsl.pipex.com%2Fimages%2Fweblog%2Fdefi_wiring.jpg&hash=501daafeda3c3b51a9af71e3919b9eac2227a35d)
Other versions
alternative gauges
52mm gauge is your choice, theres plenty out there
60mm DEFI versions require the link pod for even more cost (but may fit your needs if you wish to fit more than 1 gauge)
alternative pods
AWE kit inc guage : >> AWE link << (http://www.awe-tuning.com/pages/shared/part_detail.cfm?PMaI=3&PMoI=38&PEI=25&PP=mk5gj_20t_interior.cfm&PPT=Interior&IL=mk5boostgaugekit)
SWG Vent Pod : >> SWG link << (http://www.swgmotorsport.com/asps/ShowDetails.asp?id=190) : keeps a working vent but non angled and expensive
Pods above steering wheel are available as well.
Plus Points
Accurate and responsive
Quality gauge
Gauge has a black face when powered down
Sensor based, no pipe runs to cabin (just electrical), far better design imho
detachable connectors on back of gauge, easy to remove and put old vent back for dealer servicing if reqd
Excellent diagnostic tool with consistent feedback on engine parameters for vacuum/boost during all driving conditions
Easy to review whats normal and changes that might occur.
The way I have fitted it means all parts can be returned to stock and no OE components or wires damaged.
Looks cool
Minus Points
not a perfect match for OEM dials
too bright on normal day setting
partial loss of vent use
non std and therefore highlights to dealer of a modification (but can be removed easily see plus point)
Example Vacuum and Boost Data values
Boost wise my standard Edition 30 :
Vacuum
22 inHg idle
24 inHg in gear deceleration
Boost
12 psi peak (Tesco 99 RON, lower peak on other fuels)
3rd gear runs to 6.5 k rpm = approx 7.5 psi (0.5 bar)
Interestingly it highlights what I've always felt, that under some conditions the car does not deliver the full 12 psi on full throttle.
Often backing off and re-applying it then delivers 12 !
Seen this in other cars where progressive application to full throttle rather than slamming pedal down achieves more acceleration.
Car also seems to never deliver 12psi when applying WOT in 6th
Boost wise the remapped APR stg1 Edition 30 :
initial 20-22 psi peak on WOT , dropping to 15 psi consistent.
not checked what it is at 6.5k rpm as its a bit rapid now :grin:
Boost for other related cars
Audi S3 8P is 1.2 bar = 17.4 psi for 265 hp
ED30 Oettinger is 1.55 bar for 330 bhp
Extra info : Symptoms of DV issues
(see http://www.golfmkv.com/forums/showthread.php?t=24952)
-A failing diverter valve will generally lose boost.
-The boost can be checked either via a boost gauge, or the vag-com (mb 115).
You will see a huge drop in boost when the dv goes bad.
-Pin-hole DV failures usually allow boost to spike, but will then suddenly vent boost.
Tearing in the DV usually only allows 6-7 PSI. Boost will not spike.
-You may see 000665 - Boost Pressure Regulation: Control Range Not Reached
p0299 - 002 - Lower Limit Exceeded - Intermittent
Summary
I consider this as something VW should have fitted as an OE part.
Useful for standard cars and almost mandatory for tuned ones.
For me its DEFI for quality, the blue racer series so its self contained (other DEFI products need the link box).
Pod wise I have considered changing to the SWG version.
Its very much a personal preference on the actual gauge and pod chosen
, but whatever you choose you are going to benefit from it every day.
A must have mod for every GTI owner. :happy2:
edited to add 'negs' new south fitting guide (http://www.golfgtiforum.co.uk/index.php?topic=86564.0) from golfgti : july 09
top write up there mate with 110% detail. should help many peeps that :happy2: :happy2:
Nice one John_o :happy2:
Another mod for the list then :happy2:
You can do mine when your ready! How long do you think it would take you now you've had some practice?
cheers guys , 2hrs easy Nathan :happy2:
Why did you get the Blue Racer gauge? Why not a full Defi unit with the control-unit II?
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Ffarm4.static.flickr.com%2F3001%2F3113998341_2f75ff2143.jpg%3Fv%3D0&hash=fbb0e31a40536e438c01afd9f4c4f7a787c7fd3c)
one self contained gauge suited my needs, like I said if you plan more, or need the extra functionality then get the link gauges.
It is however even more money. personal choice only
I can see from your review that the Defi is probably a superior gauge to my Newsouth(?). I guess I was swayed by the oem vent mounting and it's exact match with the standard VW instrumentation.
Nice full review info :happy2:
Defi == $$$
@RR, Defi gauges are the best out there for the money IMO.
Defi == $$$
....You're obviously pissing excellence again! :grin: :P
Yep, based on this review and your recommendation, I'd probably buy a Defi if I hadn't already bought a NewSouth but mine does its job well enough and I only occasionally look at it what it's displaying.
for me the point i tried to emphasise with this review is that any gauge is better than none as a diagnostic tool in this instance. :happy2:
....Having had the experience of a boost leak (due to a crack in the manifold/wastegate casting) I couldn't agree more!
As I think you posted earlier, it's a stupid oversight of VW not to include a boost gauge on the Mk5 GTI. I wonder if the Mk6 will have one. IF they do I bet it won't have numeric values displayed but be just a pretty graphic like on the Golf GT(?).
^^^ Robin, when you had your boost leak wasn't your boost gauge still showing the turbo achieving 21(ish) psi?? Hence, why there was some original confusion as to what was wrong with your car? Your boost leak was so minute, that it couldn't really be picked up on the boost gauge? Please correct me if I'm wrong, my memory may be decieving me.
Also, surely if there is a problem with the car, the CEL light will go on/the driver will be able to feel something, be that through a misfire, hesitation loss of power etc etc.
Or are you saying that the point of the boost gauge is mainly as a clear and effective way to pinpoint the problem towards a boost leak?
....No, your memory is not deceiving you - The boost gauge hardly displayed the leak but it was more visible after the leak was cured and a very small increase displayed, also achieving it faster.
I think that it would be good if boost gauges had an arm which remained at a max point for say 30 seconds so that you could catch the max value more easily - It all moves so quickly. Like the way a sound level display works in pushing up a bar at its max.
Personally I think that a boost gauge is most valuable in helping to identify why you may be suddenly experiencing a loss of power but there may be a number of causes. It's less effective with a very minor leak like mine. At the very least it ticks off a list of various things to check in order to solve a problem - A process of patient elimination.
Thanks for this excellent product review John_o. You have a great skill in writing these reviews, in such away that they are simple and easy to follow and quite comprehensive.
Can all our members buy John_o some goodies so he can do more reviews. :drinking:
VW AG don't like admitting their cars have anything as untidy as engines, never mind turbochargers.
As an aside, I just recalled that the Blue Racer Defi gauge is in PSI - they don't do a metric variant do they as that version is for the US market IIRC. Still bloody good electronics in there though.
/doesn't work in old money
cmdrfire : the gauges are imported anyway so I reckon you could get the metric variant just as easily.
TC : appreciate the comments. you must have taken your nice pills today :P
edited to add wiring pic :happy2:
very helpful!
I had Defi meters fitted to my Subaru WRX with the control box fitted, so you could play back your run, you could read peaks, set audible and visual warnings etc... they were excellent.
As you can see they do support metric versions of the clocks. I had exhaust temp (i had the probe in my downpipe), oil temp and boost. I notice that you can get an enclosure that replaces the air vent on the top of the dash, with something like I had for the WRX.
The whole kit is a little expensive, but if you've made some bigger modifications - these are a must.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fss275%2Fmarkcanderson%2FDSC00714.jpg&hash=cd56fc53602b1d96dc2c93f7fe4c639ae1017f0c)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fss275%2Fmarkcanderson%2FDSC00611.jpg&hash=366d533efc96782d645024abe38e3fbffacc9056)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fss275%2Fmarkcanderson%2FDSC00753.jpg&hash=7df3072a315f36208867b87e140bce8712eed925)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fss275%2Fmarkcanderson%2FDSC00724.jpg&hash=4712a98fc5a959ddd48642fe7e081bb98f2b275d)
I had the control unit discretely mounted under the steering wheel.
Had my DEFI gauge fitted today...generally pleased with it. Shame that the blue back light doesn't exactly match the OEM blue.
Did anyone figure out how to get the dimming function to work without cutting any wires? Apparently, I need to find a 12V feed from the lighting circuit? For the moment, its set to full illumination which is a bit too bright during the night....
P.S. My gauge peaks at around 21psi... can anyone explain what the inHg and psi values mean?
i have run mine as 'night dimmed' from day1 :happy2:
never got any further on tapping into the dimmer feed as I dont like it any brighter (even during the day)
inHg - inches mercury for vacuum
psi - poundsPerSquareInch for positive pressure
Men use BAR.
Thanks, John_o. So what how does vacuum vs positive pressure affect boost?
thats a whole bigger subject but positive pressure IS boost
(i.e. you can cram more air using the exhaust driven turbocharger , and therefore more fuel into the engine = bigger bang = more power)
vacuum is the opposite condition usually when your foot is off the throttle and the pressure is negative.
only a forced induction car will show a positive large 'boost' value, but both a forced induction car and a normally aspirated will show vacuum values
my very simple 2p :happy2:
So, why doesn't my boost shoot into the PSI section of the gauge everything I press the peddle.
I always get movement in the gauge needle...but some times I can be ragging it and the dial simply moves in the lower part of the gauge, i.e. the 0-30 inHg.
Other times, the needle moves straight into the 0-30 psi bit...
Or is there something wrong?
there are some conditions where youll be in an inbetween 'phase'
(+ = psi/boost , - = mmHg/vacuum)
cruising at 85mph mine sits at -10 (i.e. its a part throttle)
general driving on light throttle I'm barely ever in +ve side
if you are on full or medium throttle you should be registering some + boost from any rpm.
going down a slip road under light throttle in 4th/5th I can make good progress and the guage registers around 5 psi
you cannot achieve large boost values at very low rpm (as the exhaust gases arent making the turbo spin fast enough)
if you were 'ragging' it , then I would always expect you to either be WOT(boost) or lift off (vacuum) , so yes you should see some boost all the time.
BUT if you go WOT in 6th gear from low rpm dont expect huge psi values.
below 2000rpm expect 3-5 psi then it should build quickly to peak around 2700 rpm (depended on the turbo you have)
as an experiment , try a straight empty road , be safe!, 3rd gear 50mph (what rpm is this)? and try going on and off the throttle to WOT , the guage should immediately go into the +ve side each and every time without fail, then back into -ve when you lift off
if it doesnt then yes you have a problem.
have you fitted an forge DV ?
do you have access to someone with VCDS who can log the car ?
let us know how you get on
Thanks John_o - from your description the boost gauge/turbo appears to be working as expected.
Got a Forge DV valve.
No access to VCDS - is there anyone nearby?
And, what is WOT short for?
check out the VCDS section where theres a list
WideOpenThrottle :happy2:
Cheerz!
hey people dose any one know where i can get hold of one of these gauges and the pod to hold it in the vent , for the gti mk5 , cant seen to see any link to buy them , could some ojne give me a link , thanks chris
as per the review, the ttshop should be able to supply you :happy2:
but you may have to email or call them for prices etc
On the Mk5 GTI I wouldn't bother mate
Google Polar FIS+ instead
whilst an excellent bit of kit, i dont feel the PolarFIS+ offers primarily what a gauge with an active sweeping needle offers.
However in terms of functions/£ it offers more, but Id still want a needle gauge. :happy2:
Good write up looks fairly easy to fit :happy2:
They are great, still running mine! and very easy to fit.
Hello just a quick one i just got my defy gauge and trying to locate the illumination so it only turns on when i turn my lights on can anyone guide me in right direction?
