All Things Mk5 => Mk5 General Area => Topic started by: 80walk on November 05, 2017, 04:01:30 pm
Appreciate this topic has already been covered before however after changing rear abs sensor and hub ive notice the car doesn't get and stay at 90deg c ... drops off when in main roads / motorway . this happened in my mk4 and simple thermostat fixed the job however understand there is 2 temp sensors in the mk5.
Is there an actual thermostat in the mk5 or is it an electrically controlled until for regulating temperature... ?
I'm guessing the sensor which is linked to the gauge in the dash is ok and it's the main temp sender in the main housing (under the alternator) as my fuel economy has dropped as well at moment ...
What's the cost of these temp sensors / units and likely install time ?
Cars standard on 85k / 2008
This link will answer your questions as it shows the how to's for a variety of job
http://www.pelicanparts.com/techarticles/Volkswagen_Golf_GTI_Mk_V/VW_GTI_Mark_V_Tech.htm
The part is less than £40 - buy genuine cause it's awkward to do and three hours if all goes well and you have a M5 tripple square for two of the fixings.
Minesbooked into get this done on Wednesday, looks like a bell of a job.
Is it the same temp sender for both the main coolant unit and sensor associated with gauge on dash ?
Just had main and in-line done on my gti, my car wasn’t getting to even 70 degrees on a 11 mile drivetrain work. Cars up to 90 in around 2 miles now. Cost me £206 for both genuine parts, new fluid and labour
... Are both the sensors the same part ?
£200!!! Jesus Christ, had new tyres on today so I’m up to £1500 I’ve spent the first month of owning it before I even start adding up the shiny bits!
which part should i be looking at ?
https://www.eurocarparts.com/car-thermostat (https://www.eurocarparts.com/car-thermostat)
Genuine coolant temp sensor is 40 quid on it's own. Genuine main thermostat is around £35 iirc, plus the second stat, sundries, coolant etc.....and the utter ball ache of getting to the main thermostat.......£200 isn't a great deal.
