All Things Mk5 => Mk5 General Area => Topic started by: GE90 on January 14, 2017, 10:43:58 pm
Hi All
Just wondered whether any fellow forum members have had their DSG remapped?
Would appreciate any feedback on which companies offer this, and whether you've been happy with the results?! My primary reason is to smooth down changes in Drive.
I am in Bromley, Kent, so somewhere local would be good, or otherwise a handheld unit to upload appears to be an option.
I'd do a DSG reset first. That should help a lot or that after a oil and filter change. The remap allows more torque from the engine, speeds shifts, allows an higher rpm limit and gives you more control of the gearbox.
I did one by GIAC. I like the torque limiter removal (my torque is 363 lb*ft), the higher rpm launch control, higher redline rpm (6900rpm), and that it stays in a manually selected gear longer before downshifting. I don't think I would opt for it unless stage 2+ (w/hpfp upgrade) or K04 :drinking:
Thanks guys. I've already done a full adaptations reset, and changed the oil and filter.
The way I look at it, if I am able to find a tuner happy to offer a refund say within 30 days if not happy, I've got nothing to lose.
If it's jerky then a remap won't fix that.
Guys at AMD (Essex) should be able to sort you out.
Thanks - email sent!
I wouldn't say it is jerky, just not very smooth in D when it changes from say 4th to 3rd, or 3rd to 2nd.
In all other respects, it is perfectly smooth.
Remap won't help. You can waste your money on one thought if you like.
This.
Will be a waste of money. Try the other routes suggested first like a dsg reset and maybe service.
Ah, OK, back to the drawing board as service and reset already done!
New mechatronics unit it is then.... or get yours refurbished.
I'm not convinced. I've have experience of a new mechatronics on my previous R32.
It's under a VW used car warranty for a little longer, but dealership doesn't agree it's a fault!
Without actually driving it its impossible to diagnose...
Yeah, you're right. It's difficult to explain.
Probably best described as far too much engine braking when no throttle applied i.e. when gently braking to a stop. When others are in the car it is quite embarrassing!
Really disappointing, as it is otherwise great!
Where are you?
Bromley, Kent. Should add that it doesn't happen all the time, but random, as in cold or warm.
The car is a MK 7 GTI, 16k miles
Have you checked your engine mounts ? They can cause jerkiness if worn out apparently.
Thanks for the suggestion, but unlikely, given the random nature, low miles and that no other symptoms of worn mounts are present.
