All Things Mk5 > Performance Modifications
ED30 APR therapy + susp mods @ Awesome
Msportman:
--- Quote from: Shoduchi on September 24, 2015, 10:55:00 am ---Your OEM dampers are equivalent to the Bilstein B6, not the B4. With lowering springs it's better to go for either Bilstein B8 or Koni Sport.
I went for the Koni with those springs. :happy2:
--- End quote ---
Is that Koni FSD's?
I am happy with stock handling except there is some role to be eliminated by use of springs and the ARB.
I just hope they don't ruin ride comfort as I am assured by Awesome they don't. The coil overs were great at lowering the car and do improve the handling but having owned and used Clubsports previously I can't warrant spending £1983 plus fitting on the car and Hand on heart the handling isn't transformed for this type of investment. They sit nice and are well damped but once on the car I rarely altered the settings.
Should be interesting tomorrow!
Shoduchi:
--- Quote from: Msportman on September 24, 2015, 03:36:11 pm ---
--- End quote ---
Is that Koni FSD's?
--- End quote ---
Koni FSD are different dampers, they're not compatible with more than a light lowering spring and there are 2 kits available: normal Golf and GTI. I have the kit for the normal version (more comfortable) and Eibach Pro-Kit springs on my GT Sport. With a 17'' wheel they're great for handling and comfort.
For more sport use the Koni Sport are better and they go well with H&R springs and ARB.
http://www.koni.uk.com/home/index.php?option=com_content&view=article&id=254&Itemid=286
Dave J:
Springs & ARB's are a good mod - worked well on my mk5 for a couple of years until the punishment was too much for the standard dampers and they effectively lost damping effect.
I went for a set of Bilstein B8's on mine to compliment the VWR lowering springs - they are designed for use with lowering springs. They are firmer, but also more cushioning of sharp bumps and are better damped at the same time.
ARB's and springs helped with the roll initially, but the Bilsteins have helped even further - for sure you will have an improvement with ARB & springs alone, but I think you may eventually seek to replace the dampers in future.
For your reference I bought mine on 47k in Oct 2012 - springs were fitted Nov 2012, ARB's in mid 2013, and then dampers replaced last month at 70k.
Look forward to your thoughts on the parts you end up with!
AJP:
That valver sounds mega. KR head on the 9a? Oh and Dave Crissell... The Man In a Shed..?
Enjoy the ed30 mate. Great cars. Don't ever get rid of that mk2 though.
Msportman:
Got to Awesome reasonably early considering the Friday rush hour commute and was greeted by Hassan who was s very knowledgeable on the ED30.
Car was immediately put into the hands of Al who is a first class mechanic and whom I trust implicitly after my previous cars he's worked on.
Great to catch with Jim and Mark as they were both very busy with APR who were over from the USA working to callibrate the RR.
First up was a full health check and RR to see how the car performed and it was good to see it was giving 235-240 on stock configuration. The cam lobe needed replacing but other than that all was healthy.
They spent the full day working on her to install the H&R springs rear spacers Poweflex anti lift and Geo.
Next was to replace HPFP with APR's item together with VWR intake and APR stage 1 V3.3 together with a cruise control for APR's switcheable maps that I had supplied.
In between I went for a spin in the MK6 R built by APR....450+ !!! Sadly the clutch packs have gone past their best but it's a serious piece of kit. It's the second time I've sampled this car the first being at Combe with Keith (ex APR).
After a full day it was back on the heavily congested M6 towards Somerset.
Navigation
[0] Message Index
[*] Previous page
Go to full version
