All Things Mk5 > How to Guides / Troubleshooting
Factory Xenon Headlight fault
r5gtt:
Hi, you do not have to remove complete bumper.
Just remove centre grill. all the screws under the arch x 4. three are 5-6 t25 torx screws underneath and you can pull the bumper away and wiggle the light out although a little tricky but can be done. 10 minute job as I did it the other day but took me 20 minutes as I wanted a look behind the bumper as I have an FMIC I'd like to fit on.
heres a link to help you :happy2:
Good luck
M
Pashka:
--- Quote from: r5gtt on December 10, 2015, 10:59:53 pm ---Hi, you do not have to remove complete bumper.
Just remove centre grill. all the screws under the arch x 4. thwre are 5-6 t25 torx screws underneath and you can pull the bumper away and wiggle the light out although a little tricky but can be done. 10 minute job as I did it the other day but took me 20 minutes as I wanted a look behind the bunper as I have an FMIC I'd like to fit on.
Good luck
M
--- End quote ---
10 min job? you are joking mate :confused:
r5gtt:
No I am not joking as I used a baby cordless with 2 torx bits and 1 philips driver without a ramp jack etc. one side can easily be taken out.
Sorry I meant to take one side of the bumper off and light out only.
TAPPY:
[/quote]
[/quote]
They are really easy to remove. I can remove a bumper on a mk5 in 5 mins :jumpmove:
I do work in a bodyshop and have removed loads though, and have access to a ramp :signLOL:
r5gtt:
--- Quote from: TAPPY on December 10, 2015, 11:47:30 pm ---
--- End quote ---
[/quote]
[/quote]I used to remove my tt mk1 bumper in 15 minutes and it has over 26 torx and two 10 mm nuts behind the arch trims.
It's piss easy to remove a gti bumper even without a ramp in comparison to the tt :happy2:
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
