Author Topic: Replacing springs guide  (Read 9463 times)
Offline Pesky jones
« on: February 09, 2016, 12:31:32 pm »
Hi
Just wanted a step by step on replacing springs all round on my mk5 DSG. I have eibach sport lines – thanks to another forum member! I’m pretty sure ill replace the top mounts and bearings at the same time with OEM.
I’ve had a little search and gained some information on swapping springs, but what would be perfect is if someone who has done the same before would be able to give me a step by step.
I’ve heard the rears are a lot simpler then the fronts. So if you want to go into detail, do so on info on the front!
Patrick2691
Re: Replacing springs guide
« Reply #1 on: February 09, 2016, 01:12:04 pm »
I'm pretty sure if you Google it there's a pictoral guide on a other forum
Sent from my LG-H955 using Tapatalk
Patrick2691
« Reply #2 on: February 09, 2016, 01:13:41 pm »
http://forums.vwvortex.com/showthread.php?5436532-Rockerdan-s-Build-Mod-DIY-Thread!!!&p=77209201&viewfull=1#post77209201
This is for the mk6 but probably very similar
Offline Pesky jones
« Reply #3 on: February 09, 2016, 01:42:27 pm »
Thanks Patrick, appreciate that
I just read through this guide, which seems like it may be accurate for my car.
http://www.swankmonkey.com/vw/jetta/2006/suspension/
I also notice they mention cutting down the bump stops, will I need to do this?
If anyone has anything to add, please do!
« Last Edit: February 09, 2016, 02:01:27 pm by Peskyjones »
Offline Pesky jones
« Reply #4 on: February 09, 2016, 02:19:42 pm »
The text in that guide looks really good, and there a fair few pictures which I can't see! Can you see it on yours @Patrick2691 ? ive tried on two different devices and browsers...
Offline shail
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,99663.msg979899.html#msg979899
« Reply #5 on: February 09, 2016, 02:30:09 pm »
Have a look here:
http://www.pelicanparts.com/techarticles/Volkswagen_Golf_GTI_Mk_V/VW_GTI_Mark_V_Tech.htm
Many many guides on the Mk5.  Under 'Suspension' you have Replacing front struts guide, and also a replace rear springs guide.
Offline Pesky jones
« Reply #6 on: February 09, 2016, 04:24:01 pm »
Thanks! That looks really good – pelican are quite good aren’t they?!
After speaking to VW and finding out top mounts and bearings for both sides coming to over 100£ (!) then I think I will inspect the top mounts at the time and probably reuse them. I am however picking up 2No. driveshaft hub bolts and 2No. lower strut pinch bolts as they are stretch bolts and will definitely need replacing
Offline Pesky jones
« Reply #7 on: February 12, 2016, 10:27:13 am »
Few questions before I tackle this tomorrow.
1) when I have the strut out, do I need a 21mm socket with a hole through the centre in order to hold the centre bolt that the nut is threaded on to still? Will it just spin if I just try and undo it without the allen key? And does this socket have to be deep, or will a normal one be ok?
2) Is it worth taking the hub nut out before I begin, as it will be better to loosen it with the wheels still attached. I've heard its a good idea as you will get more room to pull the strut out of the lower pinch?
3) Any general tips or advice from anyone?
Offline Pesky jones
« Reply #8 on: February 13, 2016, 04:52:52 pm »
anyone know where to get the vw spreader tool?
Offline doylebros
« Reply #9 on: February 13, 2016, 06:52:13 pm »
I've got 1/2 " drive torx bit ground to shape and that works fine - just an option if your stuck.
Offline Pesky jones
« Reply #10 on: February 13, 2016, 08:24:53 pm »
Tried using a 7mm allen key but it was just a tad too big to get in, and the 6mm slightly too small. Think im just going to get the proper tool too give me the best chance.
Offline doylebros
« Reply #11 on: February 13, 2016, 08:29:55 pm »
I've got a proper one in my toolbox but my modded one is the best - although I've had to use a chisel a couple of times cause certain jobs need an element of brut force. :happy2:
Offline Pesky jones
« Reply #12 on: February 14, 2016, 11:02:36 am »
Tried using a bolster, screwdriver but I couldnt get it to budge. 110k probably never been changed. Plus I used penetrating oil. Did you get the proper tool from vw @doylebros ?
Offline doylebros
« Reply #13 on: February 14, 2016, 11:10:36 am »
Tool bought VW Pullman - wasn't more than a tenner but don't rate it  - like I said some take brute force - just have a break and go back to it - it will give although you may have to up the weight of the hammer.
Offline Pesky jones
« Reply #14 on: February 14, 2016, 02:46:08 pm »
@doylebros May sound funny but where are you applying the brute force? I've heard good things about the vw tool, so think I'm going to give that a go tbh.
Also, did you undo the three wishbone bolts first and pull the hub of the driveshaft, and THEN undo the m16 bolt and try prise open the clamp?
