All Things Mk5 > How to Guides / Troubleshooting
Pulling hub off driveshaft
lukemk5gti:
I was just about to say I've done that job before, it's in my thread - http://www.mk5golfgti.co.uk/forum/index.php/topic,89715.msg907250.html#msg907250
Then I realised no I haven't.. Maybe I did on the old polo :rolleye:
Anyway, the thread has photos to refresh your thought Pesky!
Pesky jones:
--- Quote from: lukemk5gti on February 18, 2016, 03:37:15 pm ---I was just about to say I've done that job before, it's in my thread - http://www.mk5golfgti.co.uk/forum/index.php/topic,89715.msg907250.html#msg907250
--- End quote ---
Well you kind of have done the job in that thread, as part of changing of the CV boot (you gave me a lot of help when I did mine, probably wouldn't have managed it without your help, thanks again!).
So you took the hub nut, the three bottom bolts out and then put a socket through the hub, resting on the drive shaft, and tapped it? Does the driveshaft have room to move backwards out of the hub then? I would have thought the hub would have to come forward opposed to the drive shaft going backwards.
I might film stuff I do now so I can rewatch a year later when I forget :signLOL:
dazza:
I removed the nuts and left the bolts in there hence having to pull the wishbone down. :signLOL:
Then pull the hub off the drive shaft.
Pesky jones:
So, both of you separated the wishbone from the hub (definitely remember doing this)
Then, luke knocked the driveshaft out the back of the hub with a socket
Dazza pulled the hub away from the driveshaft and off the driveshaft.
At least if I try one and it doesn't work I can try the other :)
dazza:
--- Quote from: Peskyjones on February 18, 2016, 04:36:34 pm ---So, both of you separated the wishbone from the hub (definitely remember doing this)
--- End quote ---
On my other car it would not pull off so i put the hub nut in a little and tapped it with the hammer. A socket would be better.
Navigation
[0] Message Index
[*] Previous page
Go to full version
