All Things Mk5 > Performance Modifications
Intercooler advice
<< < (3/3)
Paradox1:
The sidemounts wasn't very successful on the 1.8T engines if you remember. I think where the merc would benefit on this setup is that it doesn't have the long pipes from the Turbo to the throttle body.
Personally I'm just going to get a twintercooler as it fits easy and wont take long to fit. it will flow more than I need anyway powerwise
pudding:
Yeah the 1.8T side mounts were literally made for standard boost and no more.  The TFSI front mounts can cope a lot better with the boost turned up.
Yep, short boost pipes = much more responsive!
That Merc one is a air-water though (aka 'chargecooler'), which is much better at cooling than air-air, hence it's tiny size.
Probably something I would do if going big turbo but with K03/K04 any of the aftermarket front mounts should be fine.  Is the Audi one worth it as I keep hearing it's only a tiny bit bigger than the Golf's?
dan930:
There's also the THS Ic which I think is around £500
Shoduchi:
--- Quote from: dan930 on March 04, 2016, 02:26:59 pm ---There's also the THS Ic which I think is around £500
--- End quote ---
I have a copy of that IC from DsD for £300. All made in China. For that money I'd buy another.
LVS Racing:
Forge motorsport have just dropping the price on there Intercooler for the 2.0 tfsi
http://www.shop.lvsracing.co.uk/forge-intercooler-vw-mk5-golf-audi-s3-leon-3077-p.asp
If you need any advice then please feel free to contact me
Pat @ LVS Racing
Navigation
[0] Message Index
[*] Previous page
Go to full version
