All Things Mk5 > Mk5 General Area
URGENT oil pressure stop engine
suvaralexandru:
Hello! I have a golf 5 gti, AXX 2.0 tfsi and I have the following problem:
The old cylinder head was fissured, because of the oil pump and because of me, because I didn't stop the car on time. The oil pump is now clean and cancelled the balancers, it is stil in warranty. Now I have a new complete cylinder head and after all the pieces were put again together, it appears STOP OIL PRESSURE , STOP ENGINE - red again. As far as I heard, it may be possible that the mechanic had made a mistake when he put the silicon on the cylinder head. He covered the ducts (channels). After 4000 engine-speeds it appears this error.
DerDave1:
Hello
So I have the same error message, Stop engine off bla bla bla.
Read the posts here and did as advised, sump down cleaned everything, new filter, clean oil pick up pipe, new oil, sealed it all good. Take her for a spin for about 45min, 20 min smooth to make sure the new oil is spread everywhere, and than hit her.... all good until 3 miles before home the message reoccurring Stop engine off low oil pressure. I also change the cam shaft sensor and the cam timing chain sensor....
Any good advice please what else could cause that message
DerDave1:
Hi guys
Helpful forum here! Like it.
I faced the same warning message on my MK5 2006 TFSI, and did troubleshoot.
A slight little note which is not mentioned here, my warning message has been related to the timing which was 1degree off! I figured that when I changed the timing belt, and ever than the error message vanished!
YS
Dave
Tactical_Pear:
Same thing just happened to me after racing my mate uphill. Stop! Oil pressure or whatever. So I turned the engine off without even cooling it down properly after some fast driving, checked the fluids and everything normal. After starting it up again all was fine, no message, no weird sounds. Day later still nothing while going to and out of work. Car is working perfectly. Later on we decided to go for a ride to the same location. Half way up same message. I turn on the side and quit the engine which this time was rattling. I pop the hood and after wanting to check oil that whole seal was in my hand without even unscrewing it. Completely knocked off the plastic part below engine cover. So there was air coming into where you put oil. Im like okay thats why its saying something with oil pressure. Woke up my mechanic at 2am if he could tow me. Him wanting to sleep suggested to just smack the seal onto it. Did that and trust me no air coming in or out of the oil seal now. Start the engine, sounds good, and no message. Half way home STOP! and rattling sound. I park up at my house and say to myself that Im gonna solve it tomorrow (It was round 3am by that time). I wake up ready to drive myself to my mechanics garage. Starts well and sounds good once again nothing out of ordinary. After driving for 2 minutes STOP! message appears. I say fck it and drive 14km (round 8-9 miles) to mechanic. Car was rattling as sht whole way, to me that 2.0 TFSI sounded like a diesel engine. After I got to the garage my mechanic asked if I got enough oil. I said yes as I checked like 5 times day before. Straight after he said it will be the oil pump then which is wrong. Ill post updates on my car to possibly help people with the same issue.
OllieVRS:
--- Quote from: Tactical_Pear on November 06, 2023, 01:23:36 pm ---Same thing just happened to me after racing my mate uphill. Stop! Oil pressure or whatever. So I turned the engine off without even cooling it down properly after some fast driving, checked the fluids and everything normal. After starting it up again all was fine, no message, no weird sounds. Day later still nothing while going to and out of work. Car is working perfectly. Later on we decided to go for a ride to the same location. Half way up same message. I turn on the side and quit the engine which this time was rattling. I pop the hood and after wanting to check oil that whole seal was in my hand without even unscrewing it. Completely knocked off the plastic part below engine cover. So there was air coming into where you put oil. Im like okay thats why its saying something with oil pressure. Woke up my mechanic at 2am if he could tow me. Him wanting to sleep suggested to just smack the seal onto it. Did that and trust me no air coming in or out of the oil seal now. Start the engine, sounds good, and no message. Half way home STOP! and rattling sound. I park up at my house and say to myself that Im gonna solve it tomorrow (It was round 3am by that time). I wake up ready to drive myself to my mechanics garage. Starts well and sounds good once again nothing out of ordinary. After driving for 2 minutes STOP! message appears. I say fck it and drive 14km (round 8-9 miles) to mechanic. Car was rattling as sht whole way, to me that 2.0 TFSI sounded like a diesel engine. After I got to the garage my mechanic asked if I got enough oil. I said yes as I checked like 5 times day before. Straight after he said it will be the oil pump then which is wrong. Ill post updates on my car to possibly help people with the same issue.
--- End quote ---
You'll be lucky to have a running engine after running it for that distance with insufficient oil pressure mate.
Oil pressure is required to lubricate the moving engine parts, otherwise you'll have metal on metal grinding. The rattling sound is coming from your cams and cam chain, oil pressure tensions the cam chain's tensioner on the righthand side of the engine.
Your engine needs serious investigation. The engine sump needs to be dropped, and the oil pump pick-up pipe checked for blockages, and pump balance shaft ends checked for play. Those are the most likely causes for low oil pressure on these engines. Also check the oil pump chain is still correctly tensioned, nothing there is loose.
You'll probably see A LOT of metal flakes and sparkles in the engine oil so be prepared for that.
Regardless if you find something obvious or not afterwards you will need an oil pressure test. Plug in an oil pressure gauge test tool, and monitor the oil pressure.
Once the engine warms up to 80 degrees oil temp, not coolant temp, you should take the following readings (if you can't check with car scanning tool it's around 15 min after the coolant temp hits 90):
Oil pressure at idle, 1000RPM, 2000RPM and 3000RPM. Report back what you/your mechanic get.
The oil pressure should never be below 14.5psi (1 BAR).
Navigation
[0] Message Index
[*] Previous page
Go to full version
