All Things Mk5 > Performance Modifications
Revo camcoat intake rattle?
<< < (2/2)
Tfsi_Mike:
What have Revo said?
M4T VW:
bacillus, I have that one fitted correctly and the one on the front that uses the hole from the OE intake. I have also used the spacer from the engine mount to the pipe. Still have this one bracket left unless it's meant for a KO3 setup or a different car maybe?
I have not contacted revo yet, I was just asking to see if anyone has had the same problem. I will try and take a picture of it later if i can get away from my office today.  :fighting2:
PhilNUK:
--- Quote from: Paavo on March 29, 2016, 09:15:59 am ---I also just fitted my Revo intake on Sunday. I at first used the bracket that OP describes between the engine mount and the mid section like PhilNUK did but I then realized that there was a lot of movement on the whole assembly. After realigning the heat shield I was able to get the mid section low enough to fit it directly to the engine mount using the small nylon bushing between the mount and the pipe.
I did notice that after removing the small bracket there was a lot more vibration coming through from the engine compared to when I had the bracket on. All in all I'm really not sure anymore which option would be the best.
As for the OP, the bracket will not help with rattle coming from the heat shield. But at least I was able to tighten up the heat shield so that there were no rattles so just make sure that you have everything properly fastened.
--- End quote ---
 yeah I wasn't happy with the movement with the bracket as the whole thing pivotted very easily..
Apparently they have had engine mounts on a Cupra snap when its been fitted directly to the engine.
I will have to try and dig out the pic on facebook of the intake fitted with the bracket... The bracket just looked like a cheap off cut as well.
M4T VW:
Here are the the pictures of how i have fitted mine.
This is the engine to pipe fitting using the plastic spacer. It's not that secure and does move a little.
Rear of the heat shield.
Front of the heat shield. (I fitted the rubber strip to try and stop it rattling on the radiator but it didnt work)
And the left over bracket
PhilNUK:
Yep the Revo approved place I had mine fitted at put that left over bracket between the engine mount and the mid-pipe instead of the spacer
Navigation
[0] Message Index
[*] Previous page
Go to full version
