All Things Mk5 > Sat Nav and Car Audio
MDI Interface
<< < (5/5)
Richn83:
Hi Pete,  Thanks for all the advice, I was wondering about the gear lever its probably the thing im dreading most, especially as I have DSG and not sure how you release the gear select button.
I am also planning on installing the pipe to the rear ventilation at the same time, as this wasn't installed along with the arm-rest, I can see alot of scraped knuckles and bashed heads.  But in the long-run I think it will be worth it provided I can get the car back together in good condition, I will need lots of padding, and I just know I will break or damage something  :scared:  I will let you know how I get on!
R
cameluk:
--- Quote from: Richn83 on March 11, 2010, 03:06:57 pm ---Hi Pete,  Thanks for all the advice, I was wondering about the gear lever its probably the thing im dreading most, especially as I have DSG and not sure how you release the gear select button.
--- End quote ---
Never removed the DSG lever and ashtray when I fitted my cable  :confused:
Richn83:
Camel, I was also thinking of installing the pipe for the rear blower on the armrest as I assumed I might need to remove the whole  center console, are you saying that you (and from what Pete said he) didnt actually have to remove the gear lever?  Did you just remove the front side panels, and slip/feed the cable along the side of the console?
If thats the case then I might forget about the air duct, as I dont sit in the back anyway!!!
cameluk:
I just ran the cables along the side of the centre console
When I swapped my armrest over to the cd changer/mdi version I already had the airduct running from the front.
I had to change the duct under the armrest to the version that goes around the cd changer, possibly the hardest job I have ever done on any car, I lost count how many times the air turned blue , the space for the duct is too small for it to fit into, I started to believe that they had built the whole car around the airduct
If you want to run the duct from the front then you will need to remove the dsg lever assembly
rdfcpete:
This is true as Camel says, the duct gets completely in the way!
I retrofitted my arm rest and didnt fit the duct for the rear vents for use with the climate/air con, so this wasn't a problem for me.
I wouldn't want to attempt it with the duct in its place though! This would almost be an even more frustrating retrofit if you have it in place. Good luck Rich! :signLOL:
Navigation
[0] Message Index
[*] Previous page
Go to full version
