Author Topic: Run the big ends!!  (Read 5401 times)
Offline Markis236
  • If in dout boost it out !
  • My Ride: Mk5 golf gti (ko3) mods. Audi s3 8p intercooler,psi tuning 2.5' throttle pipe,updated diverted valve,revo oil catch can
Run the big ends!!
« on: April 25, 2016, 09:53:37 pm »
So today after getting my timing belt fixed for the second time and finally getting my map sorted the STOP ENGINE light came on when I turned it off and done all the checked oil and stuff I rested it and the big ends are f*cked ! 100% rattling ! Wat would course the big ends to fail ? Besides no oil ? Because there was plenty in the sump
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=2mhrn38ci4e4e3pfd2abk2td09&/topic,19740.0.html
Re: Run the big ends!!
« Reply #1 on: April 25, 2016, 10:57:56 pm »
Well if the big end is rattling it's the shell bearings most likely. Not good :-(
Offline dronners
« Reply #2 on: April 25, 2016, 11:48:44 pm »
my guess is oil starvation from a blocked pickup
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #3 on: April 26, 2016, 06:38:30 am »
Oil starvation. Either th  pickup or the oil pump itself.
Offline Markis236
« Reply #4 on: April 26, 2016, 08:51:34 pm »
Ok took the sump off the find my oil pump chain in a hundred bits and my balancing shaft has seized ! Snapping my chain and taking the crank sprocket teeth with is so... I basically need a bottom end !!!! What engine codes and cars have the same bottom end as mine ? It's an AXX
Offline vRSAlex
  • -Receive: 253
« Reply #5 on: April 27, 2016, 07:54:35 am »
You will need a whole engine. The swarf will have travelled through to the head and fooked it. Turbo bearings may be shot too.
Follow AKS tuning on Facebook
Offline Markis236
« Reply #6 on: April 27, 2016, 07:43:18 pm »
Managed to source a BWA engine but is it a straight swap and will it run an AXX ecu ?
Offline Ricky123
« Reply #7 on: April 27, 2016, 07:48:07 pm »
Yeo you can combine axx and bwa engines. Your ecu will also be fine. Have a look threw my posts I have already done it myself. I used a bwa bottom end and axx head.
59 red mk6 GTi 5dr
57 mk5 1.9 TDi match
Offline Markis236
« Reply #8 on: April 27, 2016, 07:49:33 pm »
Iv got a deal on a complete BWA engine and gearbox for a complete pull out and drop in
Offline Juliand
« Reply #9 on: April 28, 2016, 08:17:15 am »
How much are you looking at for that - curious......in case of future failure  :thinking:
Offline DANBOY66
  • -Given: 41
« Reply #10 on: April 28, 2016, 08:25:17 am »
i have sold a few now bwa with 90k about £1000
i sold a 65k at £1200 a couple of weeks ago  :happy2:
also axx with 80k for £800 but you would be mad to buy an axx they are time bombs  :laugh:
Dan..
Offline Markis236
« Reply #11 on: April 28, 2016, 07:20:33 pm »
I paid 900 for full engine and gearbox with all the stuff still on it happy days so is the BWA engine any better or will these go bang as well ?
Offline vag
« Reply #12 on: April 28, 2016, 08:46:40 pm »
This is exactly why i replaced my oil pump chain and tensioner for piece of mind, hopefully you get it sorted soon
Offline Markis236
« Reply #13 on: April 28, 2016, 09:01:04 pm »
I phoned TPS and they wanted 1013 for oil pump and balancing shaft housing ! That's a new engine !
Offline DANBOY66
  • -Given: 41
« Reply #14 on: April 29, 2016, 08:12:30 am »
bwa are a great engine  :happy2:
when i sell an engine its complete everything except the gearbox  :wink:
Dan..
