Author Topic: How to make a PnP harness to connect an amplifier to an RNS-510  (Read 21799 times)
Offline mclovin
« on: January 13, 2010, 06:51:01 pm »
I promised I would write something up about this ages ago, so here goes!
When I bought my car I knew that I wanted to retrofit a VW RNS-510, but as I’m a bit of an audiophile I wanted to add an external amplifier and higher quality speakers for improved sound quality. I searched the Internet for a solution but the only real option I found was to add a Blaupunkt THA 475 PnP with a Blaupunkt VW OEM harness. This is fine, but it is an expensive solution and I must admit, I am not a big fan of Blaupunkt amplifiers, for the money there are much better quality amplifiers on the market so I looked into a way of adding an “off-the-shelf” amplifier of my choice to my system without having to cut any wires in the car’s original wiring harness.
As it turns out, this isn’t actually that difficult to do, I have now got my stereo set up and working beautifully using a plug-and-play harness that I built myself, as I know a lot of other people want to do something similar, I have put together this guide to building a fitting your own PnP audio harness for an external amplifier:
You will need the following items:
1.   Autoleads SOT-976 VW Harness for Bluetooth (£10-£15)
http://caraudiosecurity.com/shop/product/products_id/11957/referer/rc_googleproduct.html
2.   RCA Car 4 Channel Line Output Converter with Remote Output (£10-£40)
http://www.caraudiodirect.co.uk/celsus-lc7-four-channel-converter.html
http://shop.ebay.co.uk/?_from=R40&_trksid=p3692.m38.l1313&_nkw=RCA+Car+4+Channel+Line+Level+Converter+with+Remote+Out&_sacat=See-All-Categories
3.   Some assorted bits and bobs such as electrical connectors/soldering iron/heat shrink/harness tape etc.
Please note: If you have an MDI interface (VW iPod kit) you could use the harness that came with that kit instead of the Autoleads SOT-976 as the basis of your PnP harness, I do not have an MDI interface fitted which is why I have used the Autoleads SOT-976 as the basis of my PnP harness.
Don’t worry if you have a Bluetooth module installed (or are planning to install one) as this can also be integrated into this harness and I have included instructions on how to do this.
Step 1 – Modifying the Autoleads SOT-976 harness
The Autoleads SOT-976 is designed to be used with a  3rd party Bliuetooth kit (such as a Parrot unit) which is really handy as it lends itself very well for use with a line output converter, it looks like this:
The first thing to do is to cut the female speaker output ISO connector block off from the male Quadlock connector, like so:
Don’t cut it too short as you will want to re-use that ISO connector later on.
Step 2 – Connecting the Line Output Converter to speaker outputs
There are a few different types of Line Output converters (or LOC) on the market, here are two examples:
PAC OEM-2 (£38):
Chinese made unit available on eBay (about £10)
I purchased both units for the purposes of creating this, the PAC unit is more expensive but gives you a lot more options when it comes to how your output the signal, it is also quite well constructed but I found it a little bulky for this type of application. The generic Chinese made unit is smaller and a lot cheaper, the good news is that it’s well made, works brilliantly and it is cheap to buy. However, expect to wait at least a month for it to be delivered from Hong Kong, mine took forever to arrive! Anyway, I chose to construct my harness using the Chinese made LOC as you will see in the following photos, but you could use any type of LOC as the principle is the same, just make sure it has 4 channels and a remote output cable.
The first step is to separate out the speaker input cables from the power cables, I did this using a little bit of harness tape just to get the power cables out of the way whilst I worked with the speaker input cables.
Now all you have to do is to connect the speaker input cables on the LOC to the speaker output cables that you cut earlier on the male Quadlock of the Autoleads  SOT-976. The speaker input cables on the LOC will be labled, so just use the following pin diagram to work out which of the speaker cables coming out of the male Quadlock need to be connected to the corresponding speaker input cables on the LOC.
You only need to worry about connector block “1” as labled on the above diagram, the output pins are as follows:
1 –  Rear right loudspeaker, positive
2 –  Front right loudspeaker, positive
3 –  Front left loudspeaker, positive
4 –  Rear left loudspeaker, positive
5 –  Rear right loudspeaker, negative
6 –  Front right loudspeaker, negative
7 –  Front left loudspeaker, negative
8 –  Rear left loudspeaker, negative
Remember that diagram is drawn as you would be looking at the back of the stereo, or from the side of the male Quadlock that has all of the cables coming out of it.
You can use crimp connectors to connect these cables up, but I have chosen to solder my cables together and finish with heatshrink for a higher quality and longer lasting connection. Once done, your harness will look like this:
You can see that I’ve tucked the three power cables from the LOC behind the male Quadlock for the purposes of this photo only, so far they have not been connected to anything, so let’s get those connected now.
To do this, you will need to cut the black power ISO conector away from the female Quadlock connector on your harness, cut this pretty short, leaving as much free cable coming out of the female Quadlock as possible as you are not going to re-use the power ISO connector. Once done, your harness will look like this:
Step 3 – Connecting the Line Output Converter to power outputs
***NOTE: Skip this step if you are going to use this harness with a Bluetooth Module***
Okay, the last thing to do is to connect up the power cables and then you can wrap up the harness with harness tape and fit it to the car, it’s pretty simple, all you need to do is to connect the power input cable from the LOC to the yellow cable from the female Quadlock and the ground connector cable from the LOC to the black cable from the female Quadlock which will look something like this:
Now you just need to wrap the cables with some good quality harness tape and add a bullet connector to the remote output cable with a crimp tool and you have a finished PnP harness.
If you were wondering why I suggested keeping hold of the female speaker ISO connector that you cut off earlier on, it is so you can connect it up to the end of the speaker cables coming from your amplifier, if you route this through to behind the stereo then you simply need to connect it to the male speaker ISO connector on your wiring harness meaning that you do not have to cut or modify any of the standard speaker cables in your car – Simple! When it comes to fitting it’ll look something like this (please excuse the iPhone camera photo):
Assuming you have already fitted your amplifier (Pretty straightforward so I won’t detail that here) you are now ready fit your new PnP harness, so simply disconnect the Quadlock connector behind your stereo and fit your new PnP harness between the stereo and the car’s Quadlock connector. You then need to connect everything else up behind your stereo (RCA output, speaker cables and amplifier remote power output), refit the stereo and you’re done. Once connected, you will need to recode your stereo via VCDS/VAG-COM as the speaker out put needs to be changed from “output stage power 26 dB” to “output stage line-out 12 dB”, there is a good guide on how to do this here:
http://www.my-gti.com/1411/volkswagen-rns-510-coding-when-installing-with-a-factory-amplifier
Once recoded, you are ready to enjoy your standard VW headunit with any off-the-shelf car amplifier that you have fitted, for me this is the perfect solution as I have retained a completely standard looking interior but now have far superior sound reproduction thanks to the hidden amplifier. I would also recommend changing the standard speakers for higher quality units as well, but that is not something I’m going to include in this guide. Now, sit back and enjoy your new improved car stereo, I think you’ll agree it was worth all the hard work you’ve put into this!
Step 4 – Adding a Bluetooth module to your PnP harness
If, like me, you have a Bluetooth module such as the VW Premium, Skoda or Fiscon units that are widely available, you can easily extend the functionality of this harness allowing it to be used with these kits so you don’t need to modify the standard wiring harness in your car or fiddle about with VW repair wires and multiple connector blocks. Assuming you skipped Step 3 it’s pretty straightforward.
Note: I have the Skoda Bluetooth module fitted to my car that came with a harness, I don’t know if this differs to the harnesses supplied with the VW Premium unit or the Fiscon unit, but please note that this guide refers to the harness supplied by VRStu with the Skoda Bluetooth modules.
First thing you will notice on your Bluetooth harness is that it also needs to connect to a +12V and a ground connector, which means you can join the appropriate cables from your Bluetooth harness to the +12V and Ground input cables coming out of the LOC, you then need to connect these up to the yellow and black cables coming out of the female Quadlock connector, the Yellow cable is +12V and the Black cable is ground.
Secondly, you will need to connect up to the CAN Hi and CAN Low connectors on the Quadlock, this means cutting into a couple of cables on your harness. Going back to the VW Stereo output pin diagram, you need to focus on connector block “2” this time:
The output pins are as follows:
9 –  CAN bus, high
10 –  CAN bus, low
11 –  Display voltage supply, positive, optional for radio module low version only
12 –  Voltage supply, negative, terminal 31
13 –  Display HV CAN bus low, optional for radio module low version only, not for midline
14 –  Display HV CAN bus high, optional for radio module low version only, not for midline
15 –  Voltage supply, positive, terminal 30
16 –  Anti-theft coding control signal, SAFE, positive
So this means we need to cut the cables that connect to pins 9 and 10. These cables are brown and purple on the Autoleads SOT-967 harness, remember you do not want to sever the connection between the male and female Quadlock connectors, you just want to tap into the cables with the appropriate cables from your Bluetooth harness, once done you will have a connection that looks like this:
I would suggest that whilst you have your soldering iron handy, this is also a good opportunity to modify your microphone cable so that it will route via the RNS-510 so you can use the mute function on the RNS-510 and use voice commands, this is easily done using a length of microphone cable and some VW repair wires, a guide ton how to do this can be found here:
http://www.my-gti.com/1234/volkswagen-rns-510-microphone-connection-for-voice-control
Anyway, now you just need to wrap the cables with some good quality harness tape and add a bullet connector to the remote output cable with a crimp tool and you have a finished PnP harness. Once finished you will end up with a harness that looks something like this:
Assuming you have already fitted your amplifier (Pretty straightforward so I won’t detail that here) you are now ready fit your new PnP harness, so simply disconnect the Quadlock connector behind your stereo and fit your new PnP harness between the stereo and the car’s Quadlock connector. You then need to connect everything else up behind your stereo (RCA output, speaker cables, amplifier remote power output, Bluetooth harness and microphone cables), refit the stereo and you’re done. Once connected, you will need to recode your stereo via VCDS/VAG-COM as the speaker out put needs to be changed from “output stage power 26 dB” to “output stage line-out 12 dB”, there is a good guide on how to do this here:
« Last Edit: January 13, 2010, 07:38:41 pm by mclovin »
Re: How to make a PnP harness to connect an amplifier to an RNS-510
« Reply #1 on: January 14, 2010, 12:15:41 pm »
excellent guide dude  :happy2:
although now reinstalls my fear of doing it myself again  :ashamed:
« Reply #2 on: January 14, 2010, 12:16:20 pm »
thats a brilliant guide! massive thanks for taking the time to put it together! ;)
Offline Rob GTI
« Reply #3 on: January 14, 2010, 02:25:45 pm »
Mclovin,
With regard the re-coding do you think it would be neccessary if you only wanted one line out for a sub as thinking of it you still want the same signal for the rear speakers?
GTI Edition 30 No. 907, 3 door, Black. (Now Sold)
Offline mclovin
« Reply #4 on: January 14, 2010, 03:22:07 pm »
Rear speakers are pretty pointless, you only really hear the front speakers so I have set my system up to use the rear channels for my sub and the front channels fed through to the front speakers. When I first turned it on it was overly loud and quickly distorted as you turned up the volume but switching the output to 12dB fixed that immediately. I still get lots of nice deep bass from my sub with the low pass filter turned on so I would definitely recommend switching the output coding over to 12dB. The other nice thing about this set up is that I can quickly increase or decrease the amount of bass by simply moving the fader forwards and backwards.
If you are planning on just using the rear channel for the sub and keeping the front channel as standard I would definitely consider using a 4-channel amp to power both as it does make a big difference, however if you are going to use just the rear channels to power the sub as suggested you could probably get away without recoding the output if you turn the gain right down on the amp.
« Last Edit: January 14, 2010, 03:26:58 pm by mclovin »
Offline Rob GTI
« Reply #5 on: January 14, 2010, 03:42:36 pm »
I take your point about the benefits of the 4 ch amp although I've already got a 2 ch amp so that will have to be the way forward.  I take it you are not running any rears at all then?
Offline mclovin
« Reply #6 on: January 14, 2010, 03:52:18 pm »
Nope, don't see the point to be honest.
Offline Lovegroover
« Reply #7 on: January 14, 2010, 08:08:58 pm »
Brilliant  :congrats:
Just out of interest where have you housed your amp to utilize the standard speaker loom?
Car = 3dr K03 Gti - Shadow Blue Metallic - Monza II's - Cream Heated leather, Sat Nav, BSH True Seal, AmD Remap.
Bike = Honda CBR600FX Superlight
Offline mclovin
« Reply #8 on: January 14, 2010, 08:33:29 pm »
I have mounted my amp in the boot because I'm using the rear channel to power a subwoofer, I have just routed the speaker cable for the front channels through the car back up to behind the stereo.
I have considered moving it to under the passenger seat, but the amp I'm using at the moment won't fit under there too comfortably, so it's staying in the boot for now:
Offline Rob GTI
« Reply #9 on: January 16, 2010, 03:51:31 pm »
What have you used to secure the sub box in position?
Offline mclovin
« Reply #10 on: January 17, 2010, 07:47:25 pm »
Gravity - It's quite a heavy box!
Offline vwrascal
« Reply #11 on: March 07, 2010, 06:32:36 pm »
great write up   :congrats:, looking to do this soon, what does the pink remote wire from the LOC connect to?   :confused:
cheers
Offline mclovin
« Reply #12 on: March 07, 2010, 07:09:16 pm »
The Pink wire from the LOC gives you a remote +12v signal, it connects to the amplifier and essentially acts as a signal to turn the amplifier on when the stereo turns on and turn it off when the stereo is turned off.
