All Things Mk5 > How to Guides / Troubleshooting
Rear pad removal
<< < (4/4)
r5gtt:
You won't be able to work it back out lol
If the rubber dust seal turns with the piston get some wd 40 or similar lubricant under the rubber cap and you'll free it up. Remember it's just a dust cover.
Lewo:
--- Quote from: r5gtt on May 06, 2016, 07:59:25 pm ---You won't be able to work it back out lol
--- End quote ---
Wouldn't a few pumps on the brake pedal work the piston out?
Serious question btw, I've worked on mtb brakes this way to good effect but not got a clue with cars  :thinking:
rich83:
Why would you need to work them in an out?
r5gtt:
There is no need to work them in and out so just wind them back and job done. :happy2: pump them out with the foot brake and they'll work their way out and then you'll be back on the forum crying that your pistons have come out and you can't get them back in  :signLOL:
Lewo:
On mtbs if the pistons are sticking you can use a bit of silicon lube/brake fliud on the piston seals and work then in and out a few times which usually sorts it.
Not the same process on cars then obviously then  :signLOL:
Just wondered if it's good preventative maintenance that's all.
Navigation
[0] Message Index
[*] Previous page
Go to full version
