All Things Mk5 > How to Guides / Troubleshooting
RNS510 hums
rashg60:
OK it shouldn't be doing it after an hour definitely.
Have you upgraded your can gateway?
shoaybmakda:
As @rashg60 said might be can gateway related? Mine hums too but after about 5 mins max it stops. Mines a version P RNS510 if that helps
LondonGT:
It's been fine until today and been in there over a year. A bit weird really, I'm hoping it's just down to the weather.
The only thing I keep getting is this
Navigation
Part #: 1T0035680P
Component: RNS-MID
Coding: 04000402040000000005 (hex)
Fault codes:
03138 Input AUX IN
Radio
Part #: 1T0035680P
Component: RNS-MID
Fault codes:
03138 Input AUX IN
Thanks for your help so far, any ideas if this could make it odd? It's an upgrade not factory fit.
rashg60:
@RetroRaz any ideas with this?
john87:
The RNS510's have a cooling fan, mines runs for a good 10 minutes sometimes after I turn the car off. Must be normal.. you should hear the fan in the mk7 headunits, it's even louder! Unless what I was hearing was an electric coolant pump seeing as it was an R :confused:
Navigation
[0] Message Index
[*] Previous page
Go to full version
