Author Topic: Lower ball joint removal  (Read 10610 times)
Offline v4rley
  • -Receive: 104
« on: June 02, 2016, 08:26:45 pm »
Need to change me lower ball joint... Is it possible to remove from the hub without having to remove the driveshaft?
Have seen videos of people hitting the hub bit with a hammer on each side to shock the joint.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Lower ball joint removal
« Reply #1 on: June 02, 2016, 08:33:16 pm »
Why do you want to remove the hub?.
Just undo the bolts holding the ball jointand whack the said sides and pop the joint out.
Offline Beej
« Reply #2 on: June 02, 2016, 08:37:05 pm »
As above. 3 bolts holding it to the arm, and one through the hub, then whack away to shock it, or use a ball joint tool
Offline v4rley
  • -Receive: 104
« Reply #3 on: June 02, 2016, 09:16:10 pm »
Don't want to remove the hub, just the ball joint from it. Have just searched high and low and found my 'pickle fork' so should have a few options now. I didn't know if the shock tactic would work or not. Just a little aprehansive as attempted last week and sheared one of the three bolts so wanted to make sure I'm ready for most outcomes. Cheers  :drinking:
Offline TAPPY
  • -Receive: 56
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,103290.0.html
« Reply #4 on: June 02, 2016, 09:20:18 pm »
Where the ballpoint goes into the hub there is a slot in the back of the hub if it's really tight tap a chisel in there to open the gap slightly. Sometimes makes it easier
« Last Edit: June 02, 2016, 09:22:54 pm by TAPPY »
Offline v4rley
  • -Receive: 104
« Reply #5 on: June 02, 2016, 09:44:39 pm »
^^ don't think the mk5 have the slot?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #6 on: June 02, 2016, 10:17:50 pm »
v4rley tappy knows his stuff and nearly all cars have a slot as the bolt tightens both sides to close and hold the ball joint in. in fact that looks like a vw hub  :signLOL:
Offline TAPPY
  • -Receive: 56
« Reply #7 on: June 02, 2016, 10:18:39 pm »
Ah yeah your right sorry it's where it goes into the shock it has a slot. :stupid:
Offline TAPPY
  • -Receive: 56
« Reply #8 on: June 02, 2016, 10:19:24 pm »
I was wrong this time @r5gtt
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9 on: June 02, 2016, 10:21:56 pm »
Really @TAPPY does the ball joint just slide into the hub and bolt go through a hole and that's it.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #10 on: June 02, 2016, 10:23:55 pm »
I see it now lol just Google it and the ball joint slides up the hole and nut on top  :stupid: :signLOL:
again whack it once the nut is off. If the new ball joint spins whilst tightening it. use a jack to push the ball joint up and you should find it easier to do.
« Last Edit: June 02, 2016, 10:26:13 pm by r5gtt »
Offline TAPPY
  • -Receive: 56
« Reply #11 on: June 02, 2016, 10:25:16 pm »
Yeah I did 1 the other week and just had a moment of madness but I have done a few other front hubs since then and must have got confused  :signLOL: :stupid:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #12 on: June 02, 2016, 10:28:31 pm »
Just looked it up and yes we both had a moment of madness :stupid:  :signLOL:
« Last Edit: June 02, 2016, 10:33:13 pm by r5gtt »
Offline TAPPY
  • -Receive: 56
« Reply #13 on: June 02, 2016, 10:31:34 pm »
 :signLOL:
Offline v4rley
  • -Receive: 104
« Reply #14 on: June 03, 2016, 10:52:34 pm »
Thanks for your assistance, was even easier than expected! When undoing the top nut it backed against the driveshaft / cv joint and popped the ball joint down in the process  :pomppomp:
Have now successfully fitted this after sitting around for a year
Only casualty was my M6 triple square
