All Things Mk5 > How to Guides / Troubleshooting
Front offside wheel hits wheel liner
garrardrj:
--- Quote from: AJP on August 03, 2016, 07:55:22 pm ---
--- Quote from: garrardrj on August 03, 2016, 06:40:54 pm ---We have had it 3 years , well my son has , been owned by two other previous forum members. I expect he has duffed the front at some stage as the wheel has a slight flat spot and was put on the back when new tyres were put on it recently. Surely if there was someting like this wrong with it a service would have found the issue , especially as they put on new front tyres , replaced a bush and both CV boots ?
--- End quote ---
Probably not, unless they were looking for it and knew what to look for.
It might be a 'little kink' in the subframe. Do you have a good specialist near you?
--- End quote ---
No , great pity tbh.
AJP:
Where are you based?
doylebros:
I assume it's a MKV and it drives in a straight line and your not fighting with the steering under normal driving etc.
If the answer to the above are yes, I would look for weak shocker and part of the coil spring broken.
garrardrj:
--- Quote from: AJP on August 03, 2016, 08:07:18 pm ---Where are you based?
--- End quote ---
Ipswich , ish
AJP:
There's AKS, but they're in Bedfordshire. Bit of a trek.
Was just thinking of somewhere that has a bit of experience with these cars that could get it on the ramp for a look.
Like doylebros says though, it could be a snapped spring. I'd advise getting a second opinion at somewhere other than your usual garage.
Navigation
[0] Message Index
[*] Previous page
Go to full version
