Author Topic: Seems I need some new mods to get a map  (Read 10542 times)
Offline Spankiee
  • -Receive: 20
Re: Seems I need some new mods to get a map
« Reply #15 on: August 07, 2016, 07:21:19 pm »
on the phone he told me stage 2 is what i have to have. i only have 3 inch turbo back with 200 cell cat.?
candy white edition 30
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #16 on: August 07, 2016, 07:26:47 pm »
Anything with a bigger downpipe and decat/sport cat is Stage 2 with R-Tech.
Offline Spankiee
  • -Receive: 20
« Reply #17 on: August 07, 2016, 08:34:07 pm »
ok  :grin: just didn't tally up with that list on the first page.
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #18 on: August 07, 2016, 09:11:59 pm »
The list on the website is more of a recommended spec than minimum requirement.
Offline PhilNUK
  • -Given: 32
« Reply #19 on: August 09, 2016, 08:12:04 am »
Thanks for the replies guys..
Yeah I think I have f*cked up as I only really wanted Stage 1 numbers and didn't realise I'd entered into a world of a money pit by adding the sports cat.. So now I'm not sure whether to stay as the car is or just take the plunge..
If I do get the hpfp and go Stage 2 then am I looking at even worse mpg numbers or does the map help improve mpg?
« Last Edit: August 09, 2016, 08:14:52 am by PhilNUK »
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #20 on: August 09, 2016, 08:27:13 am »
You don't NEED any of it, you can just have a sports car and take it to Niki for Stage 2 mapping as it is. All of the mods mentioned are to extract maximum performance - just be honest when filling in the spec sheet
MPG when pootling around will be no different really, as the cars run at Lambda 1 with maximum timing for MPG/efficiency anyway, but obviously the first few weeks of honing about won't be wallet friendly
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=bd2ko0jgamj9kgffmk1o278odd&/topic,19740.0.html
« Reply #21 on: August 09, 2016, 08:33:05 am »
Haha. My car has had some kind of Map on it for 4 years now. Still struggle to get above 25mpg average. Fun though.
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #22 on: August 09, 2016, 10:46:30 am »
Not so, Dan. The HPFP upgrade I mentioned I needed wasn't to extract maximum performance. It was to cure the fuel cuts I was getting after the Stage 2 map.
Going over old ground here anyway. Nobody seems to actually read threads properly.
OP, good luck with your car.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #23 on: August 09, 2016, 11:26:33 am »
If it was needed to stop fuel cuts then either the stock pump was failing or the map was asking for too much of the standard pump and needed load/pressure requests capped further which I'm sure the tuner would do. Not ideal if not local but often peak load situations don't show themselves on a dyno
The whole point of the 'stage 2' or '2+' mapping is to differentiate between the requirement of a HPFP upgrade
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #24 on: August 09, 2016, 11:32:02 am »
I know. And as such, I wasn't expecting the Stage 2 map to ask too much of my standard pump. I think I'd heard of this once before with an R-Tech Stage 2 map. Maybe I was the lucky number two.
Anyway, I think it's wise to say that you can't guarantee a standard pump will always be ok with a Stage 2 map.
Offline PhilNUK
  • -Given: 32
« Reply #25 on: August 09, 2016, 11:48:34 am »
cheers guys and very welcome information
What about clutch? anyone had issue with stock clutch at 2 or 2+?
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #26 on: August 09, 2016, 12:36:23 pm »
Yeah, mine started slipping when I got past about 320lb/ft. I'm not saying yours definitely will (before anyone jumps in).
I reckon if your clutch is good now there's a good chance it'll cope with Stage 2. There's no real way of knowing. I'd say it's a good idea to at least budget for a clutch.
I decided to replace mine with a Helix uprated clutch with oem flywheel. They take up to 400lb/ft or thereabouts, feels like stock, except for a heavier pedal.
I couldn't rule out being close to 400lb/ft in the future so it made sense for me to upgrade.
  • -Receive: 692
« Reply #27 on: August 26, 2016, 04:36:35 pm »
Mine wasn't with stage 1, let alone 2! It couldn't support 1.5bar boost, and it wasn't going much over 120bar.   Some cars need a pump, some don't.  We even tried a brand new OEM HPFP, no difference. More flow was required, so Loba to the rescue.
