All Things Mk5 > Mk5 General Area
Which stereo?
Chesto18:
--- Quote from: Ads22 on June 24, 2018, 07:17:26 pm ---OUt of interest what is the sound quality like on these OEM upgraded units verses the original head unit. The RNS 330G plus looks attractive at the moment and interested to hear if the theres a difference.
--- End quote ---
My new 330 plus is definitely an improvement over the standard 300 if that helps.
jgalla89:
I currently have and MFD2 in my 2007 mk5 and im thinking of a 330 plus. Is it a straight swap with he cables, ive seen I will maybe need a canbus upgrade and maybe the Fakra radio aerial antenna adaptor.
anything else?
Pashka:
--- Quote from: jgalla89 on June 25, 2018, 10:40:12 am ---I currently have and MFD2 in my 2007 mk5 and im thinking of a 330 plus. Is it a straight swap with he cables, ive seen I will maybe need a canbus upgrade and maybe the Fakra radio aerial antenna adaptor.
anything else?
--- End quote ---
you would need can gateway and arial adaptor.
jgalla89:
--- Quote from: Pashka on June 26, 2018, 03:57:18 pm ---
anything else?
--- End quote ---
--- End quote ---
cool, wheres the best place to get a coded can gateway?
Ads22:
--- Quote from: jgalla89 on June 27, 2018, 08:57:18 am ---
anything else?
--- End quote ---
--- End quote ---
--- End quote ---
Would also be keen to know, ordered 330g plus with Fakra cable. Going to chance it with battery drain but would be good to know just incase. Am i also right in thinking you still get auto dim function, speed sensitive volume and radio station names?
Im also planning to add multi functions later aswell - mines manual 55 reg with Mid cluster. Would this need new steering module and slip ring. Im guessing you still keep radio station select controls?
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
