Author Topic: Poor Handling  (Read 10051 times)
Offline Matto
  • -Receive: 116
Poor Handling
« on: February 09, 2017, 08:36:05 pm »
Evening all. Just wanting to pick your brains. For a while now I have been aware that the car doesn't seem to handle like it used to. I put this down to worn standard dampers which were replaced with VWR items which improved the ride quality somewhat but were not night and day. So a little back ground on the setup:
Tyres - Michelin PSS (Summers) Nokian WR A3 (Winters)
Suspension - VWR dampers with H&R lowering springs
SALK
Whiteline RARB on stiffest setting.
I know people speak highly of the PSS's but I think they are average at best. Always wanting to push on in the corners and straight line grip in non-existent. I initially put this down to the worn dampers but once replaced there didn't seem much change. Winters are worse and understeers like a pig.
Tyre pressures are fine as is the alignment so just thought I would ask the question to see what people on here came up with.
Offline AJP
  • -Given: 392
  • -Receive: 317
Re: Poor Handling
« Reply #1 on: February 09, 2017, 08:48:10 pm »
Is the alignment definitely right? Where was it done, and on what equipment? How long ago was it done, and has anything been fitted/replaced under there since?
How much torque are you running? And is it a big lump of it at 3-3.5k, or a smoother curve? Do you have a graph of your current map?
I personally found PSS were excellent in the bends. The car still behaved like a front driver should, but they reduced understeer massively over the Kumhos that were on the previous wheels. Fantastic tyres.
I did find they'd struggle with straight line grip once they were down close to 3mm or so. Replacing them with new PS4s improved that considerably. I'm running 350lb/ft+ and still get a bit of slip in 3rd at full throttle around peak torque, but only really if it's wet or colder than around 7-8 degrees.
I won't even entertain the idea of winter tyres when in all conditions except near enough freezing a good summer tyre like the PS4 outperforms them by miles.
Last possibility... Do you think the car might ever have been in a bump?
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=lp4r4am86lgigiuae6s93ahhtc&/topic,19740.0.html
Re: Poor Handling
« Reply #2 on: February 09, 2017, 11:39:31 pm »
TBH. I think the h&r springs are dog dirt. Put some coilovers on it and it will sort it.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Poor Handling
« Reply #3 on: February 10, 2017, 12:29:55 am »
Maybe adjust the roll bar setting from stiffest setting?.
Offline AJP
  • -Given: 392
  • -Receive: 317
Re: Poor Handling
« Reply #4 on: February 10, 2017, 09:00:16 am »
Do elaborate, Rich. I'm on H&R springs and weighing up going for coilovers soon.
Offline AJP
  • -Given: 392
  • -Receive: 317
Re: Poor Handling
« Reply #5 on: February 10, 2017, 09:01:59 am »
If anything, reducing the rear roll bar stiffness would increase understeer even more. Stiff rear = more oversteer... theoretically.
  • -Receive: 692
Re: Poor Handling
« Reply #6 on: February 10, 2017, 09:29:58 am »
That is just how Golfs are.  Every MK of Golf I've owned understeers.  All FWD cars do, and so do the Haldex cars, even worse in fact.   Seems to me you are expecting something from the car it can't deliver.  Having said that, extreme traction issues and / or push on understeer that occurs too easily usually always points to bad geometry.  And you can't expect summer levels of grip right now, either.
Re: Poor Handling
« Reply #7 on: February 10, 2017, 10:20:04 am »
Night and day handling wise. I never felt that confident on the h&r springs. Seemed to be too unsettled in the bends. The PSS10s are just better. Ok the ride is hard and it's a bit annoying on motorways but once you start pushing the car, they come into their own.
Offline AJP
  • -Given: 392
  • -Receive: 317
Re: Poor Handling
« Reply #8 on: February 10, 2017, 10:39:49 am »
Cheers. I think coilovers are inevitable for me at some point.
  • -Receive: 692
Re: Poor Handling
« Reply #9 on: February 10, 2017, 10:57:14 am »
To be fair, stiffer springs with OEM dampers never was a good solution in the first place, but it suited peoples budgets a lot better.  It's why the car feels choppy and unsettled when pushed.  GOOD coilovers and GOOD fixed height kits will always work better.
Offline Matto
  • -Receive: 116
Re: Poor Handling
« Reply #10 on: February 10, 2017, 11:15:03 am »
Thanks for the replies so far. Will jump back on here with a proper reply once I'm home from work and can get on the laptop  :happy2:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Poor Handling
« Reply #11 on: February 10, 2017, 02:15:33 pm »
No I mean adjust the setting to the softer one may help?.
Offline AJP
  • -Given: 392
  • -Receive: 317
Re: Poor Handling
« Reply #12 on: February 10, 2017, 02:50:51 pm »
Like I said, reducing the stiffness of a rear bar will not reduce understeer. It will increase it.
Soft rear = understeer
Hard rear = oversteer
OP is complaining of understeer. So making the rear softer won't help.
  • -Receive: 692
Re: Poor Handling
« Reply #13 on: February 10, 2017, 03:23:00 pm »
Be careful with just an uprated rear ARB.  They do improve turn-in, which gives the impression of increasing the understeer threshold, but I had a couple of 180 pirouettes on wet roundabouts years ago, at embarrassingly slow speeds  :grin:
That's why they are sold as matched pairs  :smiley:
Offline Black9
  • -Given: 35
Re: Poor Handling
« Reply #14 on: February 10, 2017, 03:53:18 pm »
I'd really consider changing the tyres. I'm having similar issues with my C63. Currently running pilot super sports. Its a soft tyre so allows a lot of flex when cornering and traction isn't great. Previously I was running conti 5's which were great but were noisy and needed replaced.
A few owners on the merc forum have also had similar issues with pilot super sports yet some are fine with them.
I'm running pilot sport 2 or 3's on my Gti and it handles really well. Think I'll go conti 5 or eagle F1 next or maybe even uniroyal rain sport
