October 21, 2026, 11:26:46 am
All Things Mk5
Mk5 General Area
Which socket to remplace PD140 2,0tdi glow plug
Topic: Which socket to remplace PD140 2,0tdi glow plug (Read 2741 times)
Christiank
Won't Shut up.
-Given: 6
-Receive: 39
My Ride:
September 16, 2017, 11:53:10 am »
EU. So thought a 10mm long socket would do he job, however there's not enough room to reach with the socket due to the wider base.
Almost like I need an ristorante long socket?
Any tips?
MK5 TDI 2.0 MY2005 - FULL OF RETROFITS:
MK6 dashboard - BCM converted - MK7 cruise control MFSW - PLA 2.0 - 3D instrument cluster - Discover Media 2 - Highline TPMS - 10ch Dynaudio system - KESSY with start button
4ndy
Re: Which socket to remplace PD140 2,0tdi glow plug
Reply #1 on:
September 16, 2017, 07:23:17 pm »
have you tried 8mm
4ndy
Reply #2 on:
September 16, 2017, 07:35:23 pm »
extension bar
4ndy
Reply #3 on:
September 16, 2017, 07:36:59 pm »
and a pair of g p pliers or a length of pipe, hose to fit the top of the g p to remove it one unscrewed
doylebros
Just look at my post count
-Given: 44
-Receive: 310
Reply #4 on:
September 16, 2017, 07:41:30 pm »
Extract from the manual for that job below
http://workshop-manuals.com/volkswagen/golf-mk5/power_unit/4-cylinder_diesel_engine_(2.0_l_engine_2-valve_tdi)/ignition_system_glow_plug_system/checking_glow_plug_system/removing_installing_and_checking_ceramic_glow_plugs/
Christiank
Won't Shut up.
-Given: 6
-Receive: 39
My Ride:
Reply #5 on:
September 16, 2017, 08:38:11 pm »
Thanks guys. Will try again tomorrow with a smaller socket thickness.
I did you use a large 1/2" socket wrench. Think this is the problem, and why there's not enough room to get to the glow plugs.
Will keep you updated tomorrow
jason_rmh
Won't Shut up.
-Given: 69
-Receive: 81
Reply #6 on:
September 16, 2017, 10:48:27 pm »
You can get a 10mm glow plug socket from halfords.
It's a smaller thickness than a normal socket, deep enough and has a rubber grommet inside to grip the glow plug when removing.
http://www.halfords.com/workshop-tools/tools/sockets-accessories/laser-glow-plug-socket-10mm
Jas
VCDS (Preston, Lancashire)
Christiank
Won't Shut up.
-Given: 6
-Receive: 39
My Ride:
Reply #7 on:
September 16, 2017, 11:06:11 pm »
Yea, I've seen those sockets but just didn't think it would be necessary - but I'm going to put this job on hold until I'll buy one of those sockets. So will continue the injector harness along with glow plug replacement until Monday.
Since this project is on hold I can dig down to some possible retrofits tomorrow instead.
Thanks once again.
All Things Mk5
Mk5 General Area
