Author Topic: Alternator/ thermostat help  (Read 6593 times)
Offline Rigsby
  • -Given: 22
Re: Alternator/ thermostat help
« Reply #15 on: November 28, 2017, 08:19:07 pm »
For anyone wondering, spline are different to triple square.
Managed to get some proper XZN vag triple square  bits and fit perfect , thermostat is now out !!!
Offline v4rley
  • -Receive: 104
« Reply #16 on: November 28, 2017, 08:30:52 pm »
Really ? I think they are the same..... :confused:
Offline doylebros
  • -Receive: 310
« Reply #17 on: November 28, 2017, 08:40:08 pm »
Well done. :congrats:
Offline Rigsby
  • -Given: 22
« Reply #18 on: November 28, 2017, 09:02:41 pm »
Not a lot of difference but they do differ, angle of the points
Thanks for your help @doylebros
« Last Edit: November 28, 2017, 09:05:00 pm by Rigsby »
Offline Rigsby
  • -Given: 22
« Reply #19 on: November 30, 2017, 07:28:17 am »
Put her back together and it’s running rough nearly stalling?
Plus the coolant isn’t going down, I’ve only put 2 litres in and 5 came out??
Any ideas ??
« Last Edit: November 30, 2017, 07:57:52 am by Rigsby »
Offline Octoparrot
  • -Receive: 104
« Reply #20 on: November 30, 2017, 03:04:13 pm »
Sounds like an airlock, don't think that'd cause the rough running though, maybe check that everything is plugged back up properly?
  • -Receive: 692
« Reply #21 on: November 30, 2017, 03:38:42 pm »
Interesting on the triple square vs spline.  I've used splines on this job and others around the engine and not had any problems!  Bloody Germans.....premium fastener for premium engines  :grin:   They even use them on small low stress brackets where a regular 5mm allen would suffice!
Anyway...... you need to wait for the thermostat to open before it will guzzle the coolant down.  Can take ages this time of year.   Don't generally get air locks in Golfs as the expansion tank is above the engine, so air can escape.  It's usually on Jap engines with stupid radiator caps and things that air lock easily.
Offline doylebros
  • -Receive: 310
« Reply #22 on: November 30, 2017, 04:31:54 pm »
Best recheck your work on the electrical connections disturbed during the job.
Additionally, suprised you got 5lts of coolant out - what hose did you remove for the drain down?
Offline Rigsby
  • -Given: 22
« Reply #23 on: November 30, 2017, 05:30:23 pm »
Cheers folks.
Update: disconnected the maf and removed the engine cover to have a look, started it and it runs bang on, connect the maf/airbox and it struggles and cuts out?
  • -Receive: 692
« Reply #24 on: December 01, 2017, 11:46:52 am »
Have you got VCDS?  It would be handy to see what the MAF reading is, and/or if there are any fault codes.
If you haven't got it, and assuming there are no hardware/wiring problems, try disconnecting the battery and try again with the engine cover on.
Offline Rigsby
  • -Given: 22
« Reply #25 on: December 01, 2017, 07:56:57 pm »
No I haven’t got Vcds , I will try and disconnect the battery and try again.
Cars been in my garage all week now.
Seems very strange for the maf to be causing problems
Offline Rigsby
  • -Given: 22
« Reply #26 on: December 02, 2017, 01:45:43 pm »
Well the hasn’t worked, I’m at a loss now??
I suppose I’ll have to admit defeat and take it to a garage ... I hate being defeated
If anyone has any ideas please let me know, thanks
Would a vac leak cause this issue? But I’ve only removed throttle pipe and lower intercooler pipe, and theses look fine
« Last Edit: December 02, 2017, 03:47:42 pm by Rigsby »
Offline Rigsby
  • -Given: 22
« Reply #27 on: December 03, 2017, 03:35:01 pm »
FIXED- Drove it without maf connected for 5 mins until all the lights on the dash went out (from battery being disconnected) .
Turned it off, cleared fault code from the Maf being disconnected, connected maf back and runs great...........how bizarre
