Author Topic: mk6 gti steering wheel fitting advice  (Read 19288 times)
Offline rubber toe
Re: mk6 gti steering wheel fitting advice
« Reply #15 on: February 12, 2010, 10:27:23 pm »
yeah , i've already got the airbag so its just the steering wheel im waiting on  :party:
Offline ollie288
« Reply #16 on: February 12, 2010, 10:34:46 pm »
I bet that cost a fair chunk! Might not be to bad if you have the airbag though. You will love it when its fitted!  :happy2:
Offline rubber toe
« Reply #17 on: February 13, 2010, 01:45:43 am »
wasnt too bad was 300 , bargain really for what m getting  :smiley:
Offline stephen8512
« Reply #18 on: April 30, 2010, 04:11:44 am »
The mk 6 C/C stalk has partnumber 1K0 953 513 G
I think u need this in order for the steering wheel to work
Can someone confirm if Steering coloumn controller partnumber 1K0 953 549 CH is compatible with the DSG flappy paddles? As I have a jetta TFSI with DSG and i want to use flappy paddles
Offline illektronik
« Reply #19 on: May 27, 2010, 06:40:30 am »
Hi guys. Is there a DIY for this mod? That HPA Turbo R32 down here has one of these wheels and wants to fit it to his 2008 built MKV R32.
Basically it sounds like I just need to find the DIY to take off the MK5 and then fit the MK6.
Are the wiring and connections are the same? Is this slip ring an issue between the two models?
Cheers for any advice. J
Would he need to buy the 2010 Golf R or Scirocco R Steering Wheel Control Module. It's an R-Line wheel (Black trim, not silver)
« Last Edit: May 27, 2010, 06:55:12 am by illektronik »
Offline stephen8512
« Reply #20 on: June 04, 2010, 06:53:28 pm »
Hey John :)
AP already has the part numbers to get it to work but yeah to get this to work on MK5's I was told you need
1) steering column controller unit
2) "C" revision slip ring
3) MK6 Cruise control stalk
the steering column controller i'm assuming is the MK6 one. The only difference i Think between the R-Line and the normal GTI MK6 wheel is the black trim....
Offline illektronik
« Reply #21 on: June 05, 2010, 01:03:10 am »
Stephen, Anthony has the numbers, because he asked me to look into it for him. I gave him what he needed last week thanks to MortyGTI (Darren).  :happy2:
Offline stephen8512
« Reply #22 on: June 05, 2010, 07:41:02 am »
Hahahaha ahh I see. Fair enough :) I too actually got the numbers from MortyGTI on the GolfMK5 forum   :grin:
Offline TonyZed
« Reply #23 on: June 09, 2010, 12:01:15 am »
When I changed to the mk6 MFSW (no MFSW before) I had to change to this:
1KO 953 549 CH ( i ordered the BK but it didn't work with the slip ring)
Also you will need the slip ring 1KO 959 653 C (your car may have it)
Ollie :happy2:
And if you have C/C you can expect to lose it as we haven't solved that problem yet  :sad1:
Ohh yeah and that!  :happy2:
I had mine fitted today, a cruise control unit from Skoda Octavia works!! :jumpmove:
TonyZ
« Reply #24 on: June 09, 2010, 09:09:36 am »
Darren fitted a mk6 steering wheel to mine on sat..it looks excellent
http://www.mk5golfgti.co.uk/forum/index.php/topic,15463.msg226200.html#msg226200
« Last Edit: June 09, 2010, 09:11:38 am by maxitrol »
Offline stuupnorth
    • stuupnorth
« Reply #25 on: June 17, 2010, 09:33:43 pm »
Hi guys
my gti dsg doesn't have mfsw but paddles
would i be right in thinking that the mk6 wheel with paddles but without mfsw
will be a straight swap??
Stu
« Reply #26 on: June 17, 2010, 10:32:38 pm »
Hi guys
Stu
You cannot get a MK6 DSG steering without multi- function.It comes as standard onDSG wheels, and it is not a straight swap you need a new controller unit as well.  :happy2:
« Reply #28 on: June 21, 2010, 07:04:06 pm »
what about this
http://cgi.ebay.co.uk/GENUINE-STEERING-WHEEL-LENKRAD-VW-SCIROCCO-MK6-VI-DSG-/250652067663?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a5c07074f
Its not a GTI wheel but none the less, you are right. I wish i would have known this was available before i went through the whole 9 yards getting one. I could have bought that and got myself a couple of intakes with the change for what i have paid.  :sad1:  :rolleye:
Offline stuupnorth
    • stuupnorth
« Reply #29 on: June 22, 2010, 06:49:51 pm »
so what do you think
will it fit ok
