All Things Mk5 > Members Rides
My 07 BMP GTI
Pissat4motion:
Little update:
No major changes. Running Serron wheels, sequential turn signals, and a Jetta grille. Also installed an 034Motorsport upper aluminum dogbone insert to go along with the aluminum lower insert already installed.
Sent from my Pixel XL using Tapatalk
Pissat4motion:
Chased my white whale recently. Intermittent fuel cuts after driving 2+hrs in 95°+ heat. After a fuel control module and harness extension apparently didn't fix the issue, finally replaced the lpfp. Hopefully that's a remedy..
VF engineering short shifter installed. Maxton design hatch spoiler extension. Picked up a mk6 GTI trying cargo cover, difference being mk5 doesn't have the added netting underneath.
Still considering installing a mk6 GTI abs pump and module. Need to do little more research on compatible part#s
Pissat4motion:
It's winter. I'm bored. $60 for a mk6 diffuser and mk5 gti bumper. Some cutting.. a little trimming and this is it so far. Held together with clamps. Will try some plastic bonding adhesive to hold them together. If all goes well I'll pick up the stock mk6 axle back exhaust section for another~$20.
***Osir fog light covers are on the way***
Sent from my Pixel 2 XL using Tapatalk
Pissat4motion:
Closeup. Fits surprisingly well. Will sit offset from the bumper like it does on the mk6..
Pissat4motion:
More progress of the "FrankenBunny" bumper.
Also installed the OSIR fog light covers.
Navigation
[0] Message Index
[*] Previous page
Go to full version
