Author Topic: Fault after cluster swap  (Read 21892 times)
Offline Pissat4motion
« on: May 14, 2019, 05:19:26 am »
I've got one code after the swap and the abs lights on the dash. From what I've read I have a compatible abs module. I'm assuming theirs a basic setting/adaptation/ coding I haven't done.
Anyone with some insight?
Sent from my Nexus 6 using Tapatalk
Offline ady-uk
  • -Given: 19
  • -Receive: 24
Re: Fault after cluster swap
« Reply #1 on: May 14, 2019, 05:17:21 pm »
going by your name, that pump is NOT 4motion compatible.  'AC' Will never accept 4mo coding.
Have you updated ABS pump too?
« Last Edit: May 14, 2019, 05:19:59 pm by ady-uk »
VW Golf 2.0 Gtd 140 4motion (2005)
Factory fitted: xenons, sunroof, heated leather seats, fold in mirrors with downlights,
Custom: Mk6 steering wheel, updated gateway, RNS510 remote boot pop, LED lighting.
« Reply #2 on: May 14, 2019, 05:31:12 pm »
Old name from a previous car lol
It's an 07 GTI. Pump is original which is one reason it's confusing why that's the fault I'm getting
« Last Edit: May 15, 2019, 04:43:42 am by Pissat4motion »
Offline Janno2G
« Reply #3 on: September 29, 2025, 07:58:09 pm »
I have the same issue after changing my cluster to full fis. Did you ever get this sorted?
Offline JamieSmeatonVW
  • VCDS, VCP, ODIS, AVDI, Coding, Retrofits etc
  • My Ride: TFSI Caddy 2k 2010, Mk5 Gti, Bagged Jetta
« Reply #4 on: January 30, 2026, 10:47:44 pm »
Any luck?
Offline Lightynolikey
« Reply #5 on: September 23, 2026, 08:34:35 pm »
Hi. There was a company advertising on youtube to code a cluster to your car.(mk5).
Not recomending tho as not used them yet.
Good luck.
Im getting a car that isnt fussed where its clocks are from or if theres the letter "D" in the day of the week its being fitted. Its crazy were accepting this nonsense. Built in obselesence .
