Author Topic: S3 Alloy Hubs onto a GTI?  (Read 47373 times)
Offline jon-tfsi
  • -Receive: 27
Re: S3 Alloy Hubs onto a GTI?
« Reply #15 on: February 23, 2010, 01:00:16 pm »
Are the R&L aftermarket ones?
The reason I started the thread is I have a set of S3 hubs and am considering fitting them with the tt bottom arms.
I have heard the TT hubs widen the Track even further???
GOLF R Mk7
Offline jon-tfsi
  • -Receive: 27
« Reply #16 on: February 23, 2010, 01:01:54 pm »
I'm fairly sure it'll be machined alloy, rather than cast - so I can't see any strength issues. Certainly better than cast pig iron we have.
They are cast alloy but much chunkier than the iron items.
GOLF R Mk7
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
« Reply #17 on: February 23, 2010, 01:09:42 pm »
The hub carriers are double chunky, its been causing me problems as the lugs that the brakes attach to are probably twice as thick as the standard ones. So depending on the application some of the bigger caliper upgrades bolt on from the other direction and therfore need a different offset.
Thanks to Stokey for the loan of one
TBH talk of these things failing is unfounded its a substantial casting which is obviously reinforced in certain areas with the actual bearing carrier being iron, theres a small gasket to prevent dissimilar metal corrosion but the whole thing just looks right and weighs substantially less than the GTi ones
Offline laurent.d
« Reply #18 on: February 23, 2010, 01:12:23 pm »
Sorry, R&L means Right&Left!!!
I also heard that TT arms one's widen the track, but I'm not sure about it.
A3 2.0 tfsi DSG S-Line/VWR K04 Turbo kit/Engine Revo Stg 3/Milltek Exhaust/DSG Revo Stg 2/Quaife LSD/Bilstein PSS10/H&R sway bars/Power Grip Morego/VWR Suspension Bushes/VF Engineering Engine Mounts/VWR Lower Mount/OZ Ultraleggera 8x18 ET45/Brembo 328x28 2pcs 4 pot ''A'' caliper/Braille Battery
Offline jon-tfsi
  • -Receive: 27
« Reply #19 on: February 23, 2010, 02:41:04 pm »
GOLF R Mk7
Offline jon-tfsi
  • -Receive: 27
« Reply #20 on: February 23, 2010, 02:47:25 pm »
I can't imagine either if these castings failing either !!
A guy on here (VenetianS3) has stated that a hub failure ended the life of his ED30. Maybe he meant the bearing failed ??
GOLF R Mk7
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #21 on: February 23, 2010, 06:44:02 pm »
anyone know the weight difference?
Red ED35 5dr DSG
BLOG | BUILD
Offline jonnyc
  • Herrooooo!
« Reply #22 on: February 23, 2010, 06:46:06 pm »
Should be about half the weight give or take.. I would expect about 5 - 7kg for the pair..
Offline QD MBE
  • -Receive: 102
« Reply #23 on: February 23, 2010, 06:54:37 pm »
:innocent:
Offline laurent.d
« Reply #24 on: February 23, 2010, 08:48:43 pm »
S3 hubs are enormous :jumping:
ETKA:
S3 parts number : 3C0 407 253 F
                              3C0 407 254 F
TT parts number : 8J0 407 253 D
                             8J0 407 254 D
Does commun numbers (407 253/254) means that parts are the same?
Offline keith
« Reply #25 on: February 23, 2010, 09:57:10 pm »
whats the prices for the hubs?
Offline laurent.d
« Reply #26 on: February 23, 2010, 10:18:20 pm »
about 450£
Offline fuscobal
« Reply #27 on: April 05, 2011, 06:09:18 pm »
Any influence on the roll center as compared to the GTI ones ?
Mk5 GTI 6MT - Revo stage 3
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
« Reply #28 on: April 05, 2011, 08:46:36 pm »
S3 ??
No.
They're the same as Passat, Superb, Sharan 2011.
So not for true sports applications only.
The TT hubs do rise the center of roll.
BTW,
the aluminium arms are all forged for the highest strengh,
the aluminum hubs are made in special combined cast/forge
procedure called ''Cobapress'':
http://www.google.de/url?sa=t&source=web&cd=3&ved=0CCsQFjAC&url=http%3A%2F%2Fwww.st-ji.com%2Fen%2Fprocess%2Fcobapress-english.html&ei=EnGbTZ6TEcbCtAbDxoDABg&usg=AFQjCNFhL6v24BV_F4ClOx-wNwiPXdDG8g
"You get what you pay for."
Offline fuscobal
« Reply #29 on: April 05, 2011, 11:45:15 pm »
Yeah but the TT hubs don't work on our cars without touching other components either wich would prove quite expensive. I suppose TT lower arms + S3 hubs will keep a similar roll center as with GTI hubs but the weight should be nice. JonnyC said something about 5-7kg but I didn't understand if he meant the weight of a pair of S3 hubs or the difference in weight between GTI and S3 hubs. If it's the difference then I find it huge !
