Author Topic: LC5F's Graphite Blue GTI - Pilgrimage to Caffeine & Machine  (Read 77825 times)
Offline LC5F
  • -Receive: 80
Re: LC5F's Graphite Blue GTI - Sea Dweller Edition
« Reply #75 on: April 03, 2021, 02:17:07 pm »
@shannon-ob Thanks for confirming - my rears have clearanced themselves - front still rubs, but only on hard cornering - so still hopeful for some H&R's to sort out body roll - or just lift the coils up.
How much body work do you need to chop out for BTCC arches?
Offline shannon-ob
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=c1a6fajn7cufpodmjj4u1gp73r&/topic,124095.0.html
« Reply #76 on: April 03, 2021, 02:22:19 pm »
@LC5F I did think about letting mine clearance themselves when I had the 8J wheels, but when I went to 9J there would be no chance. I'm surprised that your fronts rub...
I'm not entirely sure until I buy the kit. Hopefully enough that I won't get any more rubbing issues.
MY 3 DOOR 370BHP MANUAL GTI TRACK BUILD - WAVETRACK DIFF, CAGED, POLYCARBS, KO4, DB9 BRAKES, METH, BARTEK, VIS, HELIX PADDLE CLUTCH/SMF, FLOCKED DASH, 18X9 PRO RACE
https://www.mk5golfgti.co.uk/forum/index.php/topic,124095.0.html
Instagrams;
@shannon_ob
@dinger_developments
Offline LC5F
  • -Receive: 80
« Reply #77 on: April 03, 2021, 02:50:50 pm »
@LC5F I'm surprised that your fronts rub...
its the R32 TT alloy arms pushing the wheel out further.
Good luck with the bodywork on yours
Offline shannon-ob
« Reply #78 on: April 03, 2021, 03:07:04 pm »
Ahh are they different to S3 arms?
Instagrams;
@shannon_ob
Offline colesey
  • -Receive: 89
« Reply #79 on: April 03, 2021, 07:45:42 pm »
Yep, wider track.
Offline shannon-ob
« Reply #80 on: April 03, 2021, 09:06:32 pm »
Yep, wider track.
Ohhh I never knew that! How much by do you know?
Instagrams;
@shannon_ob
Offline colesey
  • -Receive: 89
« Reply #81 on: April 04, 2021, 07:45:13 am »
From memory its @1/2” per side.
Offline shannon-ob
« Reply #82 on: April 04, 2021, 09:50:40 am »
Oh blimey! Never new that! Guessing it’ll add more negative camber too?
Instagrams;
@shannon_ob
Offline colesey
  • -Receive: 89
« Reply #83 on: April 04, 2021, 09:55:57 am »
Extra length plus adjustable balljoints so, yep, extra camber.
Offline shannon-ob
« Reply #84 on: April 04, 2021, 09:57:33 am »
Thanks for your help I’ll stop jamming up this thread I may have to invest in a pair. Could someone pm me part numbers?
Instagrams;
@shannon_ob
Offline colesey
  • -Receive: 89
« Reply #85 on: April 04, 2021, 10:23:19 am »
If you do some searching on this site, there’s parts numbers in one thread.
Offline LC5F
  • -Receive: 80
« Reply #86 on: April 04, 2021, 12:05:40 pm »
You guys have been busy! - No worries, the ones I got are 8J0407151D, only £35 a side so its not an expensive upgrade:
I went with Lemforder TT ball joints, the 3 bolt cage connecting joint to control arm seems to be surprisingly expensive and is not provided with ball joint. Ended up with anti loosening high tensile nuts and bolts
« Last Edit: April 04, 2021, 12:18:22 pm by LC5F »
Offline fakie1977
« Reply #87 on: April 13, 2021, 08:30:37 am »
Do you have part number/links to the ball joints and nuts & bolts? Thanks
Offline LC5F
  • -Receive: 80
« Reply #88 on: April 13, 2021, 07:17:23 pm »
I just looked up a M2 Audi TT R32 on ECP and it gave me 617443285 & 617443295
Nuts, bolts & washers I sourced from ebay, items I got are no longer listed - they need to be high tensile 10.9 M10 40mm (40 is a touch too long 35mm should be about right) with high tensile (if possible nyloc) nuts to suit.
In other random news, tonight I spotted this fubar'd Maserati, it makes the rust on the underside of my golf seem amateurish!
The good:
The bad:
And the ugly:
Offline fakie1977
« Reply #89 on: April 13, 2021, 07:58:11 pm »
The good:
The bad:
And the ugly:
Thanks. I assume carparts4less is exactly the same? With current sale it’s about half price compared to ECP.
