Author Topic: Driver's door wind noise problem  (Read 85 times)
Offline Sebas_theFish
« on: November 07, 2019, 06:45:44 AM »
I've recently started noticing an increase in the wind noise coming from around the mirror region on my Mk5 R32 drivers door.  Becomes most noticeable at about 80kph+.
I've disassembled the mirror and put everything back together as tight as it can go and all the parts seems to be fitting together properly. Even fully removed the mirror and reseated it on the door but it's made no difference.The seals around the mirror base look fine too.
Bit stumped what else I can do and the noise is really annoying when cruising along. Anyone had a similar issue or suggest what I could try next???
