Author Topic: Golf MK5 starts and shuts off instantly?  (Read 8924 times)
Offline hussnainh8
« on: November 15, 2019, 05:29:56 pm »
Hi
Please if anyone can guide me im puzzled with this car. I have a golf mk5 1.9 2005 I bought as a trade car thinking I could fix it as I assumed it needed a new ECU however this is not the case. The car will start but turn of instantly as if the immobiliser kicks in. There are no dash board lights when turning the ignition on except the MFD display which works (I can change the time).
I have already replaced the following:
ECU
Clocks
Body control module
Canbus gateway
Battery
Is there anything else I could look at or replace related to car starting but turning off instantly?
The codes I am getting are these:
18058 - Powertrain Data Bus
P1650 - 000 - Missing Message from Instrument Cluster
18045 - Powertrain Data Bus
P1637 - 000 - Missing Message from Electric Load Controller
02403- terminal 15 for interior
012 - electrical fault in circuit
Seems like from researching it could be many things?
Thank you!
Offline Ricky123
Re: Golf MK5 starts and shuts off instantly?
« Reply #1 on: November 15, 2019, 05:34:28 pm »
Does sound like an immobiliser issue to me but electrical issues aren’t my speciality.
Maybe try get a local auto electrician out to have a look at it or someone local to you that does key coding/immobiliser coding.
My friends mk5 gti was doing the same thing as you describe last year but he was getting a key/immobiliser light coming up on the clocks. He got a guy out and it cost him £120 for a new immobiliser chip and coding
59 red mk6 GTi 5dr
57 mk5 1.9 TDi match
Offline titchy
« Reply #2 on: November 15, 2019, 07:50:23 pm »
Don't just play parts darts get it on vcds
Offline hussnainh8
« Reply #3 on: November 16, 2019, 12:19:34 am »
What good was your reply? I have already provided the vcds codes. Explaining the codes to me would be nice.
Offline hussnainh8
« Reply #4 on: November 16, 2019, 12:20:17 am »
Tbh im at the point where I am just going to get the immobiliser deleted.
Offline titchy
« Reply #5 on: November 16, 2019, 09:03:40 am »
Srry didn't come in at the start of your post.Have you checked battery voltage. Theres a forum bbareman theres some top guys on there who can maybe help
Offline Christiank
  • -Receive: 39
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,110924.0.html
« Reply #6 on: November 18, 2019, 01:24:52 pm »
Could also be fuel problem.. Check all fuel lines
MK5 TDI 2.0 MY2005 - FULL OF RETROFITS:
MK6 dashboard - BCM converted - MK7 cruise control MFSW - PLA 2.0 - 3D instrument cluster - Discover Media 2 - Highline TPMS - 10ch Dynaudio system - KESSY with start button
Offline kpowell911
« Reply #7 on: November 18, 2019, 04:50:39 pm »
Does it do it with both keys?
Offline ady-gti
« Reply #8 on: November 18, 2019, 06:24:48 pm »
I would pull out the cluster and check the connectors and clean where needed, maybe use some dielectric grease on the pins/connector.
