All Things Mk5 > How to Guides / Troubleshooting
Magnetic number plate fixing
Top Cat:
I would try VRSapples sheets. They look good, but you might struggle with alignment, because the whole plate will be magnetic. shouldn't be a problem if you cut into small squares. :smiley:
I am on Version 3 or 4 at the minute :grin: I found the magnets would pull off after time, and the alu sheets wouldn't hold to the plate. Finally figured out it was because the mask is curved. so on my last one i glued the alu strips on, then clamped it to the mask until the glue had gone off. This seems to have solved my problems now as my plate has a permanent curve, the same as the mask. :happy2:
vRS Carl:
--- Quote from: Top Cat on September 16, 2010, 09:20:53 pm ---VRSapples
--- End quote ---
:signLOL: :signLOL: :signLOL:
That my new name is it :laugh:
afrogti:
Awesome guide TC should come in handy for me soon
Jayy26:
anyone know which magnets were used,as they is a fair few choices haha
thanks
Stooey:
--- Quote from: Jayy26 on September 23, 2015, 03:17:45 pm ---anyone know which magnets were used,as they is a fair few choices haha
thanks
--- End quote ---
I have also done this and I used n52 magnets, there meant to be the strongest vairiation of these magnets, and I have had no problems at all
Navigation
[0] Message Index
[*] Previous page
Go to full version
