All Things Mk5 > Sat Nav and Car Audio
RNS 510 display colour schemes
Neimad:
--- Quote from: Rob GTI on May 26, 2010, 10:24:22 pm ---Perphaps the error with the nav antenna is because its after market?? Or maybe not connected properly I only ever seem to get about 4 satellites out of 8 or 9.
--- End quote ---
I have an aftermarket antenna on mine and get about the same amount of satellites so I don't think that should be the problem. Might just be worth pulling the dash apart (it's a pain I know!) and making sure that the antenna is connected securely.
Rob GTI:
Just had a thought about the antenna thing. I remember while i fitted the BT I had the RNS switched on without the antenna in, perphaps this is what logged the fault code. MAybe if I clear the fault it will not repeat.
cameluk:
--- Quote from: Rob GTI on May 27, 2010, 06:48:11 pm ---Just had a thought about the antenna thing. I remember while i fitted the BT I had the RNS switched on without the antenna in, perphaps this is what logged the fault code. MAybe if I clear the fault it will not repeat.
--- End quote ---
Was that approx 6884 KM after the scan you posted above ?
Rob GTI:
I see where yourt going with this!!
Yes it does tie in, lets get re-setting and see if thats the end of that :happy2:
JPC:
Your door electrics should be sorted if you do this: window all the way down. Then window all the way up but keep your finger on the up button for five seconds after the window reaches the top
Navigation
[0] Message Index
[*] Previous page
Go to full version
