Author Topic: PCV valve change  (Read 5169 times)
Offline Jons1001
  • -Given: 22
PCV valve change
« on: March 16, 2021, 11:15:55 am »
Hi all, does anyone know if you have to change the rubber seal/gasket when fitting a new PCV? VW wanted about £25 for it so I just bought the valve itself but now wondering if I should have bought it aswell. Thanks
Offline DBXdarkangel
  • -Given: 18
Re: PCV valve change
« Reply #1 on: March 16, 2021, 11:50:04 am »
Id say its best to replace the gasket. Saves the hassle in removing it again if it doesn't seal fully.
Offline Jons1001
  • -Given: 22
« Reply #2 on: March 16, 2021, 02:43:56 pm »
Thanks, found one on ebay (genuine) for £7 ish so not too bad.
Offline GVK
  • -Receive: 77
    • GVKmotorsport
« Reply #3 on: March 16, 2021, 05:32:55 pm »
I have seen them leak so best to change gasket.
Offline Jons1001
  • -Given: 22
« Reply #4 on: March 16, 2021, 06:16:05 pm »
Cheers, does anyone know what tools are needed?
Offline GVK
  • -Receive: 77
    • GVKmotorsport
« Reply #5 on: March 16, 2021, 11:22:38 pm »
They're held on with torx bolts T25 T30 something like that.
« Last Edit: March 16, 2021, 11:25:25 pm by GVK »
Offline Jons1001
  • -Given: 22
« Reply #6 on: March 17, 2021, 09:03:10 am »
Cheers. When it see it done that quickly begs the question why did two VW specialists quote me £140 plus vat to supply and fit?! Also same for the diverter valve. One of them also told me they were giving a discount on labour as some of the same parts would be removed when fitting the pcv and diverter valve?
