Author Topic: 2008 Golf GTI MKV Sluggish Cold Start Problem  (Read 258 times)
Offline SquishySquashy
« on: September 08, 2021, 12:27:30 am »
Hi all,
New to the forum.  Just got a 2008 Golf GTI and love it.  It's recently had a major service from history.  It drives spot on though on cold starts its sluggish.  It just about starts.  Any suggestions?  All the major parts were replaced in the previous service.
Offline Kierandewberry21
Re: 2008 Golf GTI MKV Sluggish Cold Start Problem
« Reply #1 on: September 13, 2021, 06:54:03 pm »
Is it only when cold? If so Mine does this too, got told the battery so I replaced it and does it less but still does it sometimes
Offline LC5F
  • -Receive: 39
« Reply #2 on: September 13, 2021, 08:33:28 pm »
Are you talking about cranking or how it drives?
Offline Pudding
  • -Receive: 559
« Reply #3 on: September 15, 2021, 11:45:41 am »
I'm guessing it takes rather a lot of cranking before firing up.  Something not right there as they normally fire up after the crank and cam sensor sync, which is normally one crank revolution. Or a whuh whuh, vroom in plain speak  :grin:  If it's going whuh, whuh, whuh, whuh, whuh, whuh, cough, splutter, v-v-vrooom, then yeah, it's diagnosis time.
Could be literally anything.  Bad MAF, bad HPFP, bad LPFP, bad water or air temp sensors, bad plugs, bad injectors......anything.
2007 ED30 | Ohlins Coilovers | Revo Map | Plus some other stuff | Is all a GTI needs :-)
