All Things Mk5 > How to Guides / Troubleshooting
Coolant Leak
<< < (2/2)
frankoprifti:
I've been losing coolant like in a month I'm going from max line to min line. Tonight just found a place that has coolant around. It's a place just under the battery. My Golf is a Golf mk5 1.4 16v. Can you guys give me an idea what is this part that is leaking the coolant? If you check the images attached you can see that there is some water and some pink residue.
Images
https://photos.app.goo.gl/VeB9Z5bf58QxDiGaA
https://photos.app.goo.gl/niozpWAe1g9q7wtk9
Clarkj93:
--- Quote from: frankoprifti on March 10, 2022, 08:55:51 pm ---I've been losing coolant like in a month I'm going from max line to min line. Tonight just found a place that has coolant around. It's a place just under the battery. My Golf is a Golf mk5 1.4 16v. Can you guys give me an idea what is this part that is leaking the coolant? If you check the images attached you can see that there is some water and some pink residue.
Images
--- End quote ---
Hard to tell really, you could get an inspection mirror and see if you can find any hoses that have residue on them. But here's my setup which makes it easier to see because they're blue silicone for the coolant hoses, giving you an idea which ones to check and inspect for residue leaks.
frankoprifti:
I think it might be the coolant flange that found out is known to fail and its around the same area. But will visit a mechanic today or tomorrow to find out what it really is. Thank you for your picture
frankoprifti:
Found out by hand it was leaking at a place that looked like a thermostat housing
frankoprifti:
I dont know what this is called but this is which is broken on mine. Its leaking from the bottom
Navigation
[0] Message Index
[*] Previous page
Go to full version
