All Things Mk5 > Mk5 General Area
How to/tips for changing the DV on a K03
<< < (3/3)
OllieVRS:
--- Quote from: breeze on November 30, 2022, 06:57:55 am ---You don’t even need to remove the wheel arch liner. You should be able to do it based on what you can see/feel. Just make sure the hex head is in securely before you start trying to loosen and ideally replace with new bolts.
--- End quote ---
Emphasis on replacing with new bolts - when I was replacing mine the bolts were already damaged from a previous dodgy replacement and I ended up stripping one of them completely, requiring a welder to get it off  :scared:
Numero9:
I did mine recently on the driveway, using drive on ramps. Didn't take the wheel or liner off. It was manageable but needed just an extra half a foot in height to be comfortably be able to work.
No issues with the access to the part the top bolt you have to work a bit blind I used a 5mm 1/4" hex bit on an 50mm extension, was just the right length. when refitting I hand started 2 to snug to hold the DV in place before fitting the 3rd then tightening.
My bolts looked quite new still as my DV was a Rev G but still failed. Still had threadlock on them and seem okay so far.
Tip for getting the connector off is to push it in whilst pushing the tab down to then get it off.
Lewo:
Cheers, I'll pass info on to my mate and see if he's willing to have another go!
Numero9:
--- Quote from: Lewo on December 06, 2022, 10:17:27 pm ---Cheers, I'll pass info on to my mate and see if he's willing to have another go!
--- End quote ---
Where are you based? Willing to help if you aren't too far away
Lewo:
--- Quote from: Numero9 on December 07, 2022, 08:53:21 pm ---
--- End quote ---
--- End quote ---
Thanks for the offer. I'm in Kent.
Navigation
[0] Message Index
[*] Previous page
Go to full version
