All Things Mk5 > Mk5 General Area
EBC BRAKE PAD ADVICE
pudding:
--- Quote from: ljc19630 on March 23, 2023, 08:03:38 am ---
--- Quote from: Pudding on March 22, 2023, 05:19:52 pm ---I don't know many people who've had a good experience with Tar-Ox stuff :grin: Obviously Brembo, AP Racing and Alcon are the top dogs in that sector, but costly.
Yellow = A big fat hell no for a road car.
Red = Worth a punt if EBC have improved the compound in recent years as Breeze said, because otherwise, EBC are the worst pads I've ever experienced, ever ever ever!!!
DS2500 = Over rated meh. Good on paper but in practice, very underwhelming for the money. Very dusty as well, and not the 'nice' dust that wipes off easily, but the kind that burrows into wheel lacquer.
The MK7 R or S3 brakes are plenty good enough to be fair :happy2: I've used 4 pot kits in the past and the improvement never blew my skirt up to be honest, except when really standing on them from high speed with seriously sticky track pads.....but how often does that happen on the road? :grin:
I just couldn't live with the squealing, sqauwking, clicking, clacking, knocking and clunking...... and all the dust .....and the massive cost of replacement rotors (Yes you, AP Racing) blah blah. Stick to OEM brakes :grin:
--- End quote ---
Hey Kev, thanks as ever for the consice reply.
I think i'm gonna just go with standard pads, as thats the set up i had on my KO4 GTi - S3/GolfR Calipers - 345mm discs and OEM pads. That worked perfectly and not a 2nd mortgage to achive either :congrats:
--- End quote ---
The connoisseur's choice :happy2:
Marticus:
--- Quote from: Pudding on March 23, 2023, 01:08:04 pm ---
--- Quote from: Marticus on March 22, 2023, 07:16:22 pm ---Oh wow this is a timely thread as I've just bought a set of refurbed 345mm front calipers and am now wondering what to do about pads and disks.
I was hoping to find something that's not going to leave my wallet gaping, but will live through a track day or two.
Are 'standard' (ate, twr) going do work out? Anyone have experience with that?
--- End quote ---
Road pads won't hold up to track work unfortunately. They would either wear down super quick, fade to death, or catch fire, or all 3 :grin:
--- End quote ---
Yeah this was my concern, I'm also assuming that disks can warp from excessive heat. But as we can see from this thread most of the 'performace' solutions seem to have a lot of mixed opinions, add to that I lot if Internet wisdom and heresay, and it almost impossible to know what to go for.
Maybe I should check on some motorsports / track day focused forums.
ljc19630:
--- Quote from: Pudding on March 23, 2023, 01:09:40 pm ---
--- End quote ---
--- End quote ---
--- End quote ---
Thinking this set?? - https://www.ebay.co.uk/itm/402822028388?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D247414%26meid%3D83abe87ca5014ea284557a117564c306%26pid%3D101195%26rk%3D2%26rkt%3D12%26sd%3D274813758088%26itm%3D402822028388%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv11WebTrimmedV3MskuWithLambda85KnnRecallV1V4V6ItemNrtInQueryAndCassiniVisualRankerAndBertRecall&_trksid=p2047675.c101195.m1851&amdata=cksum%3A40282202838883abe87ca5014ea284557a117564c306%7Cenc%3AAQAHAAABUBEC%252B8HimpTF6XPanG8lCeF3G6jifrewDlLoKJMPz0RnJH8s%252BUBlIo2cSQSdgSGvSVvCKC6zF4X6tOnQIr392G0gldH8QjhGQ2fmdEokLVFt29UKj%252FEph29NUO0KxqhEb84gZhbKWlWfbravBJF8o5IRtXvfj2vCbzFWLfYGWKm833atPvQNNX6PCILYzrfLQsF0eokW%252BtuZ1FkFUE65hbvBl4IhHY5zgMr%252Fzz7aUvwEb1YIvuli6Q6gjDKrRKEGgc9hH1tKBOrWEDECYl9F2O50O0CncA9tvB2YBYqPzmVTSSrhIRDIZpOM56ciTLRzOHOdr5EbZ2QNGvvTFluiNqzq5kzviwXQmtxKhRqSIr78dchj5V1grvjkP2qLYHitQ6E7Ry7eOivq9gYZKqTirp1S7lAp2hlDbqLNkijxDnkqoiGwSV%252FQZDxGxCU88fJzSA%253D%253D%7Campid%3APL_CLK%7Cclp%3A2047675#vi-desc-maincntr
john_o:
ive have experience of 2 setups all using the S3 calipers.
first off get 340mm discs to remove the small unswept area if you use 345mm
clubsport ones are ideal (with split bells) but way too much ££££ imo
i ran ds2500 on both cross drilled and jhook discs on my Ed30. did several track days. i found them superb. only downside a little squeal and more than usual brake dust.
on my ed35 i got a set on 2nd hand PP GTI brakes from ebay which came with std discs and EBC Red pads, which Ive just cleaned up and fitted.
I wouldnt normally touch EBC with a barge pole but in this case Ive tried them and they arent half bad!.
under spirited driving just fine. brake dust is indeed minimal. I havent tracked them to be honest so cant report on that. I also have no idea how much abuse theyve been through prior to me fitting them!
as long as you compromise and only drive a bit hard youll be fine, but at that power level on a track dont expect much before they fade.
I always have a chat with the https://www.vagbremtechnic.com/ giving your requirements and they can help
GilesWoodward59:
--- Quote from: ljc19630 on March 23, 2023, 09:44:34 am ---
--- Quote from: GilesWoodward59 on March 23, 2023, 09:31:42 am ---I’ve used yellow stuff pads for a while now and have been impressed by the performance and feel. Interested to know why people are so against them?
--- End quote ---
What set up you running Giles?
--- End quote ---
Braided hoses, decent fluid, grooved discs. Standard calipers. Haven’t got trackday experience in the car but for a Hillclimb set up it works fine.
Navigation
[0] Message Index
[*] Previous page
Go to full version
