All Things Mk5 > Mk5 General Area
Help please. No boost and rattle noise
Northern_ED30:
I think you and me have had the exact same thing happen at the same time?!?!?!? :indifferent:
My car feels like it has no turbo, I can hear the turbo fluttering so I wonder if the wastegate is stuck open like others have said...
Onethreelee:
--- Quote from: Northern_ED30 on June 17, 2023, 06:46:41 pm ---I think you and me have had the exact same thing happen at the same time?!?!?!? :indifferent:
--- End quote ---
Well I'm feeling your pain I re scanned the car today and I'm now getting a code for the boost pressure sensor - value below lower control limit but I think that's just because the car is seeing no boost. I'm flat out busy with work ATM so hard to get time to work on the car. Maybe just have to find a reputable vag guru to take it fix it and then give me the eye watering bill.
Good luck with yours let me know how you get on
Northern_ED30:
Gonna get under mine tomorrow, someone on the forum said to check the hoses to the intercooler, if they look okay it will likely be a wastegate or actuator issue.
Will let you know
Onethreelee:
--- Quote from: Northern_ED30 on June 18, 2023, 02:52:30 pm ---Gonna get under mine tomorrow, someone on the forum said to check the hoses to the intercooler, if they look okay it will likely be a wastegate or actuator issue.
Will let you know
OK cool thanks hopefully you find your problem.
I checked all my hses already and all seem fine :(
--- End quote ---
Northern_ED30:
Checked my hoses and they’re fine too mate, borrowed a sh*tty code reader and it gave me code 01314 which says it can’t communicate with the ECM.
Think that’s a false code to be honest
This is a video I took today with my foot the the floor, is yours the same?
eature=share
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
