Author Topic: Some Help Broke Down :(  (Read 27998 times)
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=6960sdm1ekg4b8heq37sfgd7f9&/topic,90967.msg917089.html#msg917089
Re: Some Help Broke Down :(
« Reply #90 on: November 10, 2023, 10:29:34 pm »
Not long now  :party: the 18/19 link method was not good for me.
05 | Tornado Red | DSG
Offline GVK
  • -Receive: 77
    • GVKmotorsport
« Reply #91 on: November 10, 2023, 10:53:49 pm »
 Looking good. fingers crossed for a happy start-up!
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #92 on: November 12, 2023, 09:26:11 pm »
Good news and bad news.
It runs    :jumpmove:  :pomppomp: :star:
Bad news
Coolant leak from the elbow that connects to the block.
In vcds block 93 phase position is -18
Offline skkane
« Reply #93 on: November 13, 2023, 03:59:04 pm »
Timing seems off. Are you getting ~28kw actual in group 94? Here's how mine look.
2007 ED30
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #94 on: November 14, 2023, 12:59:38 pm »
maybe i should try the 18/19 method again? Currently its 19/20
But i could not get the locking tool in.
Offline skkane
« Reply #95 on: November 14, 2023, 02:26:09 pm »
18/19 is what we did when we put it back together. We had no locking tool to check but it turned out to be spot on.
2007 ED30
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #96 on: November 16, 2023, 09:13:48 pm »
 :sick: :sick: :sick: :sick:
With 18/19 link method it's worse
When I did 19/20 links
Why is the 18/19 link method not working?
Offline skkane
« Reply #97 on: November 17, 2023, 09:40:37 am »
Damn, that looks way worse. Only things I can think about are the actual camshaft install into the head, the locking tool should slide in there without any force or wiggling if all is set properly. Either that or the timing belt side, are you certain that it's on spot? Here's two photos of how my cam positions looked with the current timing I have.
2007 ED30
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #98 on: November 17, 2023, 10:44:16 am »
Thanks for the pics
The belt side looks good.
Even when the head was off i could only get the locking tool in at 18/19 links with a lot of wiggling.
I suppose i will set back to 19/20
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #99 on: November 18, 2023, 02:31:02 pm »
Now it's back to 19/20 pins
« Last Edit: November 18, 2023, 08:33:54 pm by dazza »
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #100 on: November 18, 2023, 08:38:06 pm »
Checked my bottom timing mark.
After a spin to the shops phase position bank 1 is now -16
No other errors
Offline skkane
« Reply #101 on: November 19, 2023, 12:52:03 pm »
Mine used to be -9kw on group93 with the old engine. I'd run it but fk do I know :stupid:. Group 91 looks good with actual meeting requested. A bit baffling though as mine and all the others i've seen request 28kw at idle vs your 24kw, was that with the engine up to temp?  Maybe someone with more experience can chime in.
« Last Edit: November 19, 2023, 12:54:40 pm by skkane »
2007 ED30
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #102 on: November 20, 2023, 01:10:46 pm »
Yes it was up to temp. The motor is an axx maybe this is why some readings are different.
Going to drive it for a few days to see if it improves.
Offline skkane
« Reply #103 on: November 20, 2023, 01:32:36 pm »
AXX being a bit different makes sense since they used slightly different cams vs my older BYD and this CDL, had CDL cams on the BYD aswellso maybe that's why I'm getting the 28kw.
2007 ED30
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #104 on: December 18, 2023, 08:28:13 pm »
The car has done a thousand km now. The fluid levels were good until yesterday when I noticed a patch on the floor. I think it's from the water pump.
« Last Edit: December 18, 2023, 08:31:10 pm by dazza »
