Author Topic: Edition 30 engine cover same as a gti?  (Read 3142 times)
Offline mk1mad
« on: December 18, 2023, 05:20:28 pm »
I have recently bought an Edition 30 with an induction kit, I am not that  keen on the noise and would   like to refit the original engine cover/airbox.
Are there any parts specific to the edition 30 that I will need ? or can I buy a k03 gti airbox?
Edition 30
Golf Mk1 5vT
Offline GVK
  • -Receive: 76
    • GVKmotorsport
Re: Edition 30 engine cover same as a gti?
« Reply #1 on: December 18, 2023, 06:59:32 pm »
Air filter element is a different part number, so I'm pretty sure they are different.
Offline mjmallia
  • -Receive: 60
« Reply #2 on: December 19, 2023, 09:23:26 am »
Engine covers are all the same for the GTI, S3, Leon Cupra, Octavia etc with the 2.0 TFSI.  Only difference is the badging/branding panel on top.
The Ed30 and S3 filters are slightly shorter in height and have an A or B at the end, and supposed to improve air flow apparently (what difference it actually makes I have no idea), otherwise the same shape.
I interchange between the standard GTI and Ed30/S3 filter depending on the cost at the time without issue.  (I seem to find the ED30/S3 filter cheaper most of the time)
Mike
South Coast
Offline mk1mad
« Reply #3 on: December 19, 2023, 09:46:40 am »
Thanks for the replies, one further question is the pipe from the airbox to the turbo Ed30 specific to allow the diverter valve pipe to connect ?
Edition 30
Golf Mk1 5vT
Offline mjmallia
  • -Receive: 60
« Reply #4 on: December 20, 2023, 08:41:16 am »
Its K04 engine cars, so ED30, S3 etc
I have one on my K03 GTI as I relocated the DV to the K04 location.
Mike
South Coast
  • -Receive: 692
« Reply #5 on: December 21, 2023, 03:57:58 pm »
ED30 engine cover has 2 plastic clip clamps for the DV pipe. K03 does not.
Could probably add those easily enough to a K03 cover though.
Offline mjmallia
  • -Receive: 60
« Reply #6 on: December 22, 2023, 08:14:30 am »
Good point as I had to add them when I did the K04 DV relocation.
The clips are cheap and two holes need to be drilled........locations are on the cover already  :happy2:
Mike
South Coast
Offline skkane
« Reply #7 on: December 22, 2023, 01:00:04 pm »
I'd recommend getting a HPFP cover plate if you're going to put the engine cover on. The sensor on top has been known to crack due to vibrations and you will need a new HPFP if that happens as they're not sold separately.
It looks like this -> https://www.vismotorsport.com/product-page/hpfp-cover-shield-suport-inox
2007 ED30
