All Things Mk5 > Sat Nav and Car Audio
RNS 510
cameluk:
Current can gateway is 1K0 907 530 AD £153 from the dealer and is version AD
Anything above version L will be fine
About an hour to change over, once you have found it
Note down everything ticked in the current gateway, i.e Engine, ABS etc
Install the new Gateway
Reprogram the gateway with the same options selected as the old one, note that items may move around in the list
Clear any errors with VCDS
Go for a short drive to reset the ABS and Steering Wheel
Job done
Oh and scare yourself silly when the rear wiper doesn't work until you have been driving for a while :chicken:
cameluk:
Looks like version AF is now available
ILoveTuna:
This is all sounding a little bit complicated to me!! Can anyone recommend a good fitter in the midlands area to fit/supply and fit a RNS 510?
:smiley: :smiley:
Hedge:
I'm pretty sure Ben @ Shark Performance would fit your RNS but I doubt he would supply that would be down to you.
Worth an ask though. :smiley:
cameluk:
Fitting a RNS is really easy, I swapped mine for a C in under 20 minutes
Swapping the can gateway is harder especially if its located above the pedals - the VW designer must have been having a really bad day when deciding where to locate it
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
