General > Detailing
Abrasive polish....worth it?
Jules86:
--- Quote from: Boothy on June 23, 2010, 08:46:40 pm ---So could I use the sonus ssx1, followed by my existing lusso cleaners/polish and then the lusso wax? I just want something I can use to get rid of the swirls but continue to use my lusso products as I've been impressed with the results.
--- End quote ---
Yes mate, you use abrasive polish and follow with a polish to restore (non abrasive) the brand isnt important.
You wont manage more than a 60-70% defect removal by hand though.
Boothy:
Cheers Jules. Might order a sample pot and see what difference it makes. Even 60% correction is better than nothing I suppose.
winrya:
Don't use any machine polishes by hand, the micro abrasives are designed to break down at different stages at heats you just can't generate by hand. Fillers are your best bet with vag paints, something like megs nxt 2 is the best I've found. Menz are awesome but intensive polish, rather than final finish is far more easy going on vag paint. It finishes LSP ready and removes far more imperfections in one hit. But, machine only!
Best product for hand correction is megs scratch x but in my experience, it has no effect at all on my diamond pearl paint
S2 Ant:
Going against what you've jsut put, i dont particularly rate Megs stuff at all and its generally more pricey than anything else as well.
I recently toyed with some AG Paint Renovator on the GF's car as it had some light scratches and major swirls. Lots of elbow grease later the bonnet had the light scratches pretty much totally removed but the swirls were too much for my "Mr Muscle" arms lol
When i get a DA i'll try do the job properly tho
autoperfection.com:
Hi Boothy,
If you're polishing by hand we'd recommend going for something like Poorboys Super Swirl Remover 1, which is much better suited to hand polishing than most others, which are best suited to the higher speeds created by using a machine.
http://www.autoperfection.com/shop/Poorboys-Super-Swirl-Remover-1-16oz.html
If the swirls are really bad and you want as much correction as possible, you could go for Super Swirl Remover 2 first, which is more abrasive, but you will need to then refine this with the 1 afterwards.
http://www.autoperfection.com/shop/Poorboys-Super-Swirl-Remover-2-16oz.html
Have to disagree with Jules on the SRP though, whilst it does have fillers in it, it is actually abrasive, which is why it's used as a polish.
If you already have the Menzerna Final Finish you can use this by hand, but you have to be prepared to put in some serious elbow grease as it will take much longer to achieve results by hand, but it will work!
Hope this helps
Taryn and Jim :happy2:
Navigation
[0] Message Index
[*] Previous page
Go to full version
