All Things Mk5 > Sat Nav and Car Audio
RCD/RNS 510 - K CAN Gateway
<< < (2/2)
coop:
2680, how do I go about updating it?
vRS Carl:
You need to download the latest firmware (2760) from VWNavi
Burn that to disc.
To load firmware is pretty straight forward.
1. Unlock your car > Get in > DO NOT PUT KEY IN IGNITION
2. Power up the RNS-510 without key in ignition > eject any CD or DVD in the RNS-510 insert your Firmware CD
3. Unit will restart and after a couple of minutes it will ask you to press OK > wait a couple more minutes and you will get another OK to press.
4. Leave the update to run for approx 50 minutes > once it’s done eject the CD and reload maps from DVD.
Just be aware you can brick the RNS if you have a dodgy one (i.e its been opened up and the EEPROM soldered to reset the code) Only way to tell is check to see if the security seals are still intact. If they aren't then you run the risk. If they are still intact you should be ok :happy2:
AnSGTI:
--- Quote from: coop on August 10, 2010, 06:11:58 pm ---I've just fitted a rns510 Ver C with bluetooth to my 07 which is on K revision can. Most things work although voice control dosent and the satnav has an issue where it thinks its in germany until it gets a gps lock, which can take up to 5 minutes. Both things may be fixed my coding the unit which I havent done yet, ive only plugged and played so far.
--- End quote ---
I'm probably going to go for an RCD510 I think but it's positive that you've fitted an RNS 510 Version C to a car with a K CAN gateway. No problems with the battery at all then?
Thanks to everyone who's replied
coop:
Thanks allot for the advice carl, ill give it ago this weekend.
Ansgti, no battery problems so far, its been working now for about two weeks. Cheers
AnSGTI:
I had my car scanned and it revealed the following:
1K0 907 530K
J533 Gateway H04
H04 (Hardware)
0021 (Software)
Does this fit with other K CAN people?
Cheers!
Navigation
[0] Message Index
[*] Previous page
Go to full version
