Author Topic: RNS 510 Firmware  (Read 11143 times)
Offline coop
RNS 510 Firmware
« on: August 12, 2010, 09:32:46 am »
Hi Guys
Im looking to update the firmware on my RNS 510 and have realised that in doing so i will loose my European maps, as my unit didn't come with any DVD is there any way I can backup the maps to a sd card before I update the firmware?
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
Re: RNS 510 Firmware
« Reply #1 on: August 12, 2010, 09:56:57 am »
Not all firmwares remove the maps.
272x doesn't for definate. Pretty sure 268x & 276x don't either.
What version is your RNS
Offline coop
« Reply #2 on: August 12, 2010, 03:04:14 pm »
You advised me on another post to go for 2760. I'm on veer c. Cheers
Offline coop
« Reply #3 on: August 17, 2010, 09:34:55 pm »
im looking to update my firmware to 2760, has anyone tried the firmware found here: (you will need to be a member to view the link)
http://vwnavi.com/showthread.php/13764-Volkswagen-RNS-510-Firmware-Upgrade-to-version-2760-2762-2764-2766-2768
Im not sure if i can go for this firmware as there is no mention of being able to upgrade a ver c on firmware 2680 to 27.... on this upgrade guide
http://www.my-gti.com/2291/volkswagen-rns-510-firmware-upgrade-to-version-2760-2762-2764-2766-2768
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #4 on: August 17, 2010, 09:40:16 pm »
If you have a version C RNS it should upgrade fine.
Just ensure you have a genuine unit. Check the security seals and if they are intact you will be fine to upgrade. If they are not you risk bricking the device as it may have had it's EEPROM soldered to reset the security code :happy2:
Offline mortygttdi
  • -Receive: 146
« Reply #5 on: August 18, 2010, 03:26:43 pm »
Be careful I have seen units that still have the seals intact and still brick
All the sellers are doing is replacing the seals with photocopied ones on stickers and cutting the stickers to size, they do look good but you can tell just by running your finger over them...genuine ones will be very thin and feel quite smooth over the edges where has copied ones will have a pronounced lip cos the sticker is quite thick.
Darren :happy2:
Offline coop
« Reply #6 on: August 18, 2010, 11:55:59 pm »
Just tried installing firmware 2760 and I get a software error at the start of the installation, ive tried burning to a dvd and a cd both have the same issue. Is there a certain type of disk I need to use, or maybe you cant install version 2760 on firmware 2680, anyone had similar problems?
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #7 on: August 19, 2010, 05:54:10 am »
I installed 2760 onto 1024 firmware so I can't see why not :confused: Have you downloaded the correct firmware? Not one modified for an octavia?
Just checking  :smiley:
Offline coop
« Reply #8 on: August 19, 2010, 10:40:04 am »
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #9 on: August 19, 2010, 07:25:00 pm »
This one if you have above K Revison Gateway.
2760 Firmware
This one if you have below K revsion to stop Battery Drain
2760 No Battery Drain
Offline coop
« Reply #10 on: August 19, 2010, 09:56:22 pm »
thanks, but which one if you have the K gateway?
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #11 on: August 19, 2010, 10:27:03 pm »
Sorry should have said K or above.
The first one is what you want if you have a K or above gateway :happy2:
Offline pat15312
« Reply #12 on: August 20, 2010, 10:45:54 am »
if your upgrading the firmware then might be an oppertunity to download new maps (i think were on V6 now) and then insert speed camera POI's
i did it, was a doddle and its really helpful in the long run. if you wanna do it you will need:
this guide - http://www.mk5golfgti.co.uk/forum/index.php?topic=2092.0
and...
a subscription to these guys for you POI's - http://www.pocketgpsworld.com/
I have some proper OEM look image files which are loads better than the crap ones people have made (if i do say so myself lol)
Audi S3 s-tronic (Week 46)
Phantom Black | Black styling pack | Titanium 18" alloys | LED headlights
Super sports seats | Bang & Olufsen | Advance key | Interior lighting pack
Technology pack | Audi Connect | Parking System Plus | Reverse Camera
AAC | Hold assist | Pre-sense | Headligh assist | Privacy glass | TPMS
Offline coop
« Reply #13 on: August 20, 2010, 09:22:02 pm »
Help, I've just installed the update 2760, all seemed to go ok but now my satnav dosent work, no visible satellites.
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #14 on: August 20, 2010, 10:37:39 pm »
Leave it on for about 10 mins as the firmwares sometimes delete the Satnav Almanac (directory of where they are in the sky) and it can take 10-15 mins for it to rebuild. Make sure the antenna has a clear view of the sky.
